    regexp with hashes help
    regexregex
    16 Posts 3 Posters 4.4k Views 2 Watching
    • P Offline
      patrickdrd
      hello,
      I would like some help with a regexp I was trying to write a couple of days ago but I didn’t succeed,
      well,
      I want to select wholes lines (in order to delete them with \1) which contain “#” (without the quotation marks of course) in any positon, but only those that aren’t followed immediately after by “#” or by “@”
      for the time being I ended up with #\s, but what I’m asking would be more effective obviously,
      thanks in advance
      • P Offline
        patrickdrd
        hmm, it seems there are cases like this too that I would like to exclude:
        google.*###center_col > #resultStats + div[style=“border:1px solid #dedede;margin-bottom:11px;padding:5px 7px 5px 6px”]
        so maybe the hash has to be the only hash in the line
          Scott Sumner @patrickdrd
          @patrickdrd
          Your request is unclear. I want to say that you want to match all lines with exactly one # character occurring in them, but I don’t think that is correct…
          • P Offline
            patrickdrd
            ok, send me the first request to check and I’ll tell you what results I want omitted
              @patrickdrd
              • P Offline
                patrickdrd
                what???
                  @patrickdrd
                  I’m certainly willing to assist, but I have no clue what “send me the first request to check and I’ll tell you what results I want omitted” means. (Which to me is the long form of my earlier response of “???”.)
                  • P Offline
                    patrickdrd
                    thanks a lot,
                    I was talking about the original, first message,
                    ignore the follow-up for now,
                    we’ll talk about them after the initial results
                      Hello, @patrickdrd, @scott-sumner and All
                      Scott, I suppose that @patrickdrd was expecting your first regex attempt, in order to test it on real data ! However, I must admit that the @patrickdrd’s formulation looks like more as an imperative order than a polite request for some regex help :-(
                      Anyway, @patrickdrd, I’ll try to give you some hints !
                      Here is, below, the general form of the regex S/R which deletes all lines containing, exactly, n times the Char character ;-))
                      SEARCH ^(?:([^Char\r\n]*)Char){n}(?1)\R
                      REPLACE Leave EMPTY
                      In your case, as you, probably, want to delete all lines containing, exactly, 1 hash char, only, whatever its location, the correct regex becomes :
                      ^(?:([^#\r\n]*)#){1}(?1)\R
                      which can be shortened as :
                      ^([^#\r\n]*)#(?1)\R
                      Notes :
                      • The [^#\r\n]* part represents the longest range, even null, of characters different from # and line-breaks, stored as group 1 and re-used, after the # symbol, in the (?1) sub-routine call syntax, which is equivalent to [^#\r\n]*
                      • As usual, the \R form matches any line-break, whatever the file type ( Windows, Unix or Mac )
                      • P Offline
                        patrickdrd
                        sorry guys, I didn’t mean to be impolite, I just didn’t express myself properly
                        • P Offline
                          patrickdrd
                          ok, I’ve just tested guy038’s suggestion and it’s not “safe” because
                          it matches these lines I would like excluded:
                          @@.jpg#$image,domain=comando-filmes.org
                          @@.png#$image,domain=fbfriendrequest.com|igflash.com|likesgroup.com
                          *.png#$image,redirect=2x2-transparent.png,domain=idsly.com
                          *.png#$image,redirect=2x2-transparent.png,domain=premiumtoss.com
                          *.jpg#$image,redirect=2x2-transparent.png,domain=300mbfilms.org
                          *.png#$image,redirect=2x2-transparent.png,domain=golrojadirecta.com
                          *.gif#$image,redirect=1x1-transparent.gif,domain=totaldebrid.org
                          .png#$image,domain=driverdestek.com
                          so maybe my best shot is #\s
                            Scott Sumner @guy038
                            Gotta love the sub-routine syntax…why write something like [abc]{5} when you can write (?+1)(?'name'[abc])(?1)(?-1)(?&name) ? :-D
                            Example shamelessly stolen from here after I read up on it…and OK, that example includes named groups as well…but all good stuff (that works in N++).
                              @patrickdrd
                              Hey, you’ve been around long enough to know to indent every line of example text with 4 spaces before posting. :-)
                              (Noticed that you escaped some * but apparently not all because some of your text is in italics…way easier to just indent 4 and forgetaboutit)
                                Hi, @patrickdrd, @scott-sumner and All
                                Scott, your regex use of the (?1) syntax made me laugh a lot ;-)) Of course, it would be ridiculous to use such a regex !
                                So, the generic regex S/R, of my previous post, which deletes all lines containing, exactly, n times the Char character can, also, be written :
                                SEARCH ^(?:[^Char\r\n]*Char){n}[^Char\r\n]*\R?
                                REPLACE Leave EMPTY
                                Now, generally speaking, when you want to delete some lines of a file, based on a criteria, just determine :
                                • The common characteristics of all the lines which have to be to kept
                                OR the opposite :
                                • The common characteristics of all the lines which have to be deleted
                                patrickdrd, reading more carefully, and from your last example, it’s seemed that you would like to delete, either :
                                • All lines, containing the #$ string
                                • All lines, containing more than one hash character #
                                In that case, use the regex S/R, below :
                                SEARCH ^.*#(.*#|\$).*\R?
                                REPLACE Leave EMPTY
                                • P Offline
                                  patrickdrd
                                  no, sexually l actually I want to keep those lines and the ones posted above, it’s an awkward one, I know
                                  • P Offline
                                    patrickdrd
                                    damn auto correct…
