    VIM color scheme help
    3 Posts 3 Posters 1.8k Views 2 Watching
    • TypicalSEET Offline
      TypicalSEE
      Hi~ I kind of like the default color scheme(default.vim) of VIM7.4 on CentOS(just as the picture below shows). How can I use the same color scheme on notepad++?I mean, how to edit the file stylers.xml…… Thanks a lot!
      Picture on Onedrive https://1drv.ms/u/s!AiOPdsmUbQYthtQYnKrgcQfvKZ0qFw
        Scott Sumner @TypicalSEE
        @TypicalSEE
        See Settings (menu) -> Style Configurator… and start experimenting.
        • chcgC Offline
          chcg
          There are already some predefined themes you may want to take as starting point for your adaptions.
