    Keep unsaved tabs open between sessions
    3 Posts 2 Posters 961 Views 1 Watching
    • Bob BarringerB Offline
      Bob Barringer
      I had a different laptop a few months ago. I had Notepad++ set to keep my unsaved tabs open until I manually closed them. I cannot get this newer laptop to do it though.
      I thought checking the Remember current session for next launch box might do the trick, but apparently not.
      • Eko palypseE Offline
        Eko palypse @Bob Barringer
        @Bob-Barringer
        if you want to keep unsaved notes you need to enable
        session snapshot and periodic update as well.
        Eko
          Bob Barringer
          Looks like that worked. Thank you.
