    while search comments how to exclude in notepadd++?? i need plugin same.
    6 Posts 3 Posters 2.7k Views 2 Watching
    • Indrk toyouI Offline
      Indrk toyou
        Unfortunately, you haven’t described your problem in much detail, so it’s hard for us to help.
        I am guessing here, but I think you are looking for a plugin that will help you while searching the source-code you are editing – I think you want to either search just the comments, ignore matches in actual code; or, oppositely, you want to search just the actual code, and ignore matches in the comments – but I’m not sure. If this is an accurate interpretation, please let us know which one (or both, if you want either ability). Either way, I don’t know of a plugin that does that – it would probably have to be programming-language dependent (because different languages do comments in different ways – some have single-line comments, some multi-line, and some both): if my interpretation is right, please also let us know what programming language or languages you want to be able to do this in.
        If I’ve guessed wrong, please see the FAQ I linked above, and provide us with more information as to what you want.
          Indrk toyou
          Sorry for the inconvenience and thank you so much for your replay :) :) !!!
          Problem :
          In the C programming while search code comments also it will list. I need only source code and ignore the comments while search in the notepad++. I need plugin same.
            Indrk toyou
            Problem :
            I need only source code and ignore the comments while search in the notepad++ for c programming . I need plugin same.
              Thank you for clarifying. Like I said, I don’t know of any plugins that do that, but there might be one.
              However, @guy038 or one of the other regex gurus might be able to come up with a regular expression that looks for foo, as long as it doesn’t come on the same line after //, and as long as it doesn’t come between /* and */ even on multiple lines. My regex ability doesn’t extend quite that far.
              Here is some example text that such a regex should handle
              void foo(void) { // match the foo to the left, but not these foo to the right
                  int bar = foo(); // match this one, too
                  /* bar = recurse() + foo();    // nope, it's inside multiline comment, so should be ignored
                  i = foo();  // not here either
                  return(foo());  // but match this one
              I started with just trying to match foo not after //, using regex=(?!//)*foo or (?!//).*foo, but neither of those worked (I am not really good at the negative lookbehinds and other “does not contain this multicharacter string” regular expressions. Some day, after reading enough of Guy’s regex, I hope to get to that level… but I’m not there yet.) And until I get that, there’s no way I could get it to also not match anything between the /* and */.
                Hello, @indrk-toyou, @peterjones and All,
                Ah ! Peter, I needed some time to figure out the correct regex, but it should, indeed, match all occurrences of the word foo, which are, both, outside multi-lines comments /*.....*/ and before any // start of a line comments ;-))
                Note that finding a regex that matches each kind of C comments was rather easy ! However taking these two features in account, in a same regex, was really a tricky work !!
                So, if options Regular expression and Wrap around are selected, in the Find/Replace/Mark dialog, a possible solution is :
                • (?-i)((?s)/\*.*?\*/((?!/\*).)*?|(?-s)(\G|^)((?!//|/\*).)*?)\Kfoo , if you want to match the word foo, with its exact case
                • (?i)((?s)/\*.*?\*/((?!/\*).)*?|(?-s)(\G|^)((?!//|/\*).)*?)\Kfoo , if you want to match the word foo, whatever its case
                So, assuming the text below ( Please, no coherent C code, Just to verify that the regex does work as expected ! )
                The regex finds /marks 21 occurrences of foo !
                "foo"                        // First match
                void foo(void)   foo  {      // Match the word foo, before //, but NOT these foo, located after FIRST //
                    foo
                    int bar = foo();    foo  // match the TWO strings "foo"
                foo
                    foo        foo           /* bar = recurse() + foo(); // foo INSIDE a multi-lines comment, so should be IGNORED
                    i = foo();               // Word "foo" still IGNORED !
                    foo  */  foo = foo * 7   // The FIRST "foo" is IGNORED, only !
                /*  foo                         A SECOND multi-lines comment, containing some foo strings
                       foo
                 foo*/
                      /* foo                    And a THIRD multi-lines comment !
                  foo*/
                    return( foo());          // Match "foo" BEFORE the // symbol for comment LINE
                    foo()
                foo/* foo */foo              // One-line comment block with foo, surrounded with two words "foo" OUTSIDE comment
                foo/**/foo                   // "foo" OUTSIDE One-line comment block
                foo /* foo                      Two consecutive TWO-lines comment blocks, containing foo, split on THREE lines
                */ foo  /*
                foo */  foo
                s = "foo"                    // LAST item (foo)
                Notes :
                • Of course, you may replace the word foo by any string or, even, a complete regex !
                • This regex does not handle some oddities as, for instance, */......./* or nested multi-lines comments /*..... /*.....*/....... */
                • BEWARE : If you need to delete or replace all occurrences of the string foo, outside comments, with something else, you must use the Replace All button, exclusively and not the Replace button ( step-by-step replacement )
                • Allow me to not explain this regex, right now ! I need to think about it, again. May be an easier solution will comes to my mind ;-))
                • Probably, I just missed a very easy way ! ( In France, we have an expression : “like the tree which hides the forest” ! ) So, I’m waiting your solutions !
                Best regards,
