    Changing from Default Style causes printing of blank pages
    3 Posts 2 Posters 1.5k Views 2 Watching
    • James BeckJ Offline
      James Beck
      I think the title says it all.
      If I go into the “Style Configurator” and change to anything other than the default style, my HP ColorJet will only print blank pages. It doesn’t matter if I set the printer properties to print in color or black and white.
      Am I missing some setting to correct this?
        Does the same happen with other printers (such as a print-to-PDF or some other physical printer)?
        What version of Notepad++ are you using (? > Debug Info > Copy … to clipboard and paste it here)
        What are your Settings > Preferences > Print settings?
        this FAQ shows more details about how to provide us with more useful information for helping you debug.
          … for example, I took a document I happened to have open, printed it to PDF using PDFCreator, and it was fine. I then changed to “VIM Dark Blue” theme, and printed to PDF, and it was still fine.
          Debug Info =
          Notepad++ v7.5.8   (32-bit)
          Build time : Jul 23 2018 - 02:03:53
          OS : Windows 10 (64-bit)
          Plugins : ComparePlugin.dll dbgpPlugin.dll DSpellCheck.dll MarkdownViewerPlusPlus.dll NppConverter.dll NppExec.dll NppFTP.dll PluginManager.dll PreviewHTML.dll PythonScript.dll XMLTools.dll mimeTools.dll NppExport.dll
