    Function List - Help for adding a custom language
    8 Posts 3 Posters 2.6k Views 1 Watching
    • M Offline
      Mateos81
      The game Wolfenstein Enemy Territory has a bot mod called Omni-Bot, which has a scripting part powered by the Game Monkey script language
      It has as such added some particular functions etc. which are bundled through its repository with a custom Notepad++ installation
      Currently, it has a parser definition that roughly works: it captures almost all the “namespace” and function names, but at the same level
      Here it is:
      <code>
      <parser id=“ob_function_old” displayName=“Omni-Bot (old)” commentExpr=“((/*.?*)/|(//.?$))”>
      <function mainExpr=“^[ \t]*(global |member )?([0-9A-Za-z_.]+)(\ *)=(\ )function(\ )(([0-9A-Za-z_,\ ]))" displayMode=“$functionName”>
      <functionName>
      <nameExpr expr="^[ \t]
      (global |member )?\K[0-9A-Za-z_.]+”/>
      </functionName>
      </function>
      </parser>
      </code>
      I’d like to improve it so the functions are inside the “namespaces”, and that all parts are captured
      I ran the various regular expressions in regex101 to check them, but they doesn’t seem to work once in the N++ file
      Here is the script I’ve modified:
      <code>
      <!-- ========================================================== [ GM ] -->
      <!-- GM - Game Monkey script for Omni-Bot -->
      <parser
      displayName=“Omni-Bot”
      id =“ob_function”
      <classRange
          mainExpr    ="\w*(global)\s+([0-9A-Za-z_\.]+)\s*\=\s*(function\(\s*\w*\s*\)){0,1}\s*\{"
          openSymbole ="\{"
          closeSymbole="\}\;"
          <className>
              <nameExpr expr="\w*(global)\s+\K[0-9A-Za-z_\.]+" />
          </className>
          <function
              mainExpr="\s*\K[0-9A-Za-z_\.]+\s*\=\s*(function\(\s*[0-9a-zA-Z_\.]*\s*\))?\s*\{"
              <functionName>
                  <nameExpr expr="\s*\K[0-9A-Za-z_\.]+"/>
              </functionName>
          </function>
      </classRange>
      </parser>
      </code>
      And here is an example file:
      https://pastebin.com/Uk9jdfzw
      The current definition outputs:
      <code>
      navigate
      OnEnter
      Test
      Test2
      OnMapLoad
      OnBotJoin
      InitializeRoutes
      </code>
      The goal is to have something like:
      <code>
      Map
      Navigation
      jump
      navigate
      Roles
      Axis
      DEFENDER
      DEFENDER1
      AxisBridgeSuicide
      OnEnter
      Test0
      Test
      Test2
      OnMapLoad
      OnBotJoin
      InitializeRoutes
      </code>
      (What’s above it supposed to be indented but heh I’m probably using the wrong MarkDown stuff)
      My modified parser just outputs nothing atm…
      The script part in userDefineLang.xml is the same between these two, I don’t think you need that in order to help?
      Do you see what’s wrong? ^^’
      Thank you in advance,
      Regards,
      Mateos
      • R Offline
        rinku singh
        modify the exiting language for test
        as css
        #define IDM_LANG_CSS (IDM_LANG + 10)
        • M Offline
          Mateos81
          What do you mean by the “exiting language”? Where should I put this line?
          R 1 Reply Last reply Reply Quote 0
          • R Offline
            rinku singh @Mateos81
            @Mateos81
            well in function list.xml go to line no. 59
                 <association id="my_parser_id" userDefinedLangName="My UDL Name" />
            • M Offline
              Mateos81
              Ah I have this there:
              <association id= “ob_function_old” userDefinedLangName=“Omni-Bot (old)” />
              <association id= “ob_function” userDefinedLangName=“Omni-Bot” />
              That’s what I use to test; like now if I switch through the N++ menu to either of these languages, well original works but mine don’t
              I should have precised that’s present in the file yeah, without you can’t select the language ^^’
              Edit: And ofc related entries in userDefineLang.xml
              • R Offline
                rinku singh
                @Mateos81 said:
                i think this was a only comment
                uses is as
                replace
                • M Offline
                  Mateos81
                  Hmm I think it’s already the case, or I’m mistaking something?
                  I have two association and parser tables, one is Omni-Bot (old) and the other is Omni-Bot in functionList.xml, same in userDefineLang.xml
                  Old works fine, it’s the new one the issue, it doesn’t seem to parse anything
                  Have you tried adding these to your files and checked the two configurations?
                    Hi, @mateos81 and All,
                    Concerning your present parser :
                    <parser id="ob_function_old" displayName="Omni-Bot (old)" commentExpr="((/\*.*?\*)/|(//.*?$))">
                        <function mainExpr="^[ \t]*(global |member )?([0-9A-Za-z_\.]+)(\ *)\=(\ *)function(\ *)\(([0-9A-Za-z_\,\ ]*)\)" displayMode="$functionName">
                            <functionName>
                                <nameExpr expr="^[ \t]*(global |member )?\K[0-9A-Za-z_\.]+"/>
                            </functionName>
                        </function>
                    </parser>
                    I modified and simplified the different regexes, in the same way I did, in my previous post ! So, I ended up with this version :
                    			<parser
                    				commentExpr="/\*.*?\*/|//.*?$">
                    				<function
                    					mainExpr="(?-i)^\h*(global\x20|member\x20)?[\w.]+\x20*=(\x20*function\x20*\([\w,\x20]*\))?\s*\{"
                    					<functionName>
                    						<nameExpr expr="(?-i)^\h*(global\x20|member\x20)?\K[\w.]+"/>
                    					</functionName>
                    				</function>
                    			</parser>
                    Remark :
                    • Because of the in-line // comment, the function AXIS does not appear in the function-list panel. Logical !
                            AXIS = // Team
                    So, three work-around syntaxes are possible :
                            AXIS = {  // Team
                                AllBots = true, // Each bot is considered for a role
                    or :
                            AXIS = {
                     		 // Team
                    or :
                            // Team
                            AXIS =
                    Note that, with the 1st solution, there must be, at least, two blank characters, between the { and the start comment //, although I don’t understand exactly why ;-))
                    Given your example file :    https://pastebin.com/Uk9jdfzw    and using the syntax AXIS = { // Team, the function List panel displays the 22 elements, below :
                    Map
                    Navigation
                    jump
                    navigate
                    Roles
                    AXIS
                    DEFENDER
                    DEFENDER1
                    AxisBridgeSuicide
                    OnEnter
                    Test0
                    Test
                    Test2
                    Test_3
                    OnMapLoad
                    OnBotJoin
                    InitializeRoutes
                    MapRoutes
                    BUILD_Command_POST
                    NonFunctionClassLevelTest
                    NonFunctionClassLevelTestWithFunction
                    Test
                    I didn’t study your enhanced parser, with classRange node, yet ! I hope to be able to get some results as I know very little about objects classes :-((
                    P.S. :
                    To test your parser, I used the following association
                    			<association id=   "ob_function_old"   langID= "0"  />
                    which enabled me to simply use Normal Text language ;-))
                    IMPORTANT : Follow the link, below, for further discussion !
                    https://community.notepad-plus-plus.org/post/53905
