    regex: Match string not containing string
    14 Posts 4 Posters 26.8k Views 1 Watching
    • Neculai I. FantanaruN Offline
      Good day. and Merry Christmas !!
      I have this lines all starting with tag <p class=“TESTA”> and ending with tag <br> except the last two.
      <p class="TESTA">I love you.<br>
      <p class="TESTA">You love her.<br>
      <p class="TEXTA">She loves me.<LLbr>
      <p class="TEXTA">It is not about me.<AAbr>
      My output result should be
      I made a regex, but is not too good. I use ?! and \b but seems it is not a very good idea.
      (?-s)(.*<p class="TEXTA">.*)(?:(?!\b<br>\b))(.*)$
      • R Offline
        rinku singh
        try compare
        https://regex101.com/r/We7Afi/1
        https://notepad-plus-plus.org/community/topic/16817/regex-find-all-lines-starting-with-a-specific-tag-and-ending-with-a-different-tag/3
        • Meta ChuhM Offline
          Meta Chuh moderator @Neculai I. Fantanaru
          hi @Neculai-I.-Fantanaru
          merry christmas to you too !!
          this regex will work on your given example:
          find what: ^(.*?)TESTA(.*?)(\r\n|\r|\n)
          replace with: (leave empty)
          search mode: regular expression
          click on replace all
          so from your example:
          every line will be deleted except:
            yes, @gurikbal-singh , I inspired myself from a previous topic, but it’s not the same thing. This is why I open another topic, even if it’s close.
              yes, I find the solution. I believe my mistake was the fact I also use (?-s) in a negative lookahead regex. Doesn’t work this way.
              <p class="TEXTA">(?:(?!<br>).)*$
              or
                Hello, @neculai-i-fantanaru, and All
                In order to match complete non-empty lines which do NOT contain a specific string, let’s say, the word TEXT, with that exact case, here are, below, 5 regexes :
                • Regex A : (?-is)^(?!.*TEXT).+\R matches any line which does NOT contain the string TEXT
                • Regex B : (?-is)^(?!^TEXT).+\R matches any line which does NOT contain the string TEXT, at beginning of line
                • Regex C : (?-is)^(?!.*TEXT$).+\R matches any line which does NOT contain the string TEXT, at end of line
                • Regex D : (?-is)^(?!^TEXT|.*TEXT$).+\R matches any line which does NOT contain the string TEXT, at beginning OR at end of line
                • Regex E : (?-is)^(?!^.+TEXT.+$).+\R matches any line which does NOT contain the string TEXT, NOT at line boundaries
                In the table, below, the lines matched are noted with a X and therefore, will be deleted, if the Replace zone is empty
                |              Lines Scanned              |  Regex A  |  Regex B  |  Regex C  |  Regex D  |  Regex E  |
                |  TEST : I love you.                     |     X     |     X     |     X     |     X     |     X     |
                |  TEXT : She loves me.                   |           |           |     X     |           |     X     |
                |  ABCD : It is not about me.             |     X     |     X     |     X     |     X     |     X     |
                |  TEXT : You love her.                   |           |           |     X     |           |     X     |
                |  Statement "TEST" : I love you.         |     X     |     X     |     X     |     X     |     X     |
                |  Statement "TEXT" : She loves me.       |           |     X     |     X     |     X     |           |
                |  Statement "ABCD" : It is not about me. |     X     |     X     |     X     |     X     |     X     |
                |  Statement "TEXT" : You love her.       |           |     X     |     X     |     X     |           |
                |  I love you.          = TEST            |     X     |     X     |     X     |     X     |     X     |
                |  She loves me.        = TEXT            |           |     X     |           |           |     X     |
                |  It is not about me.  = ABCD            |     X     |     X     |     X     |     X     |     X     |
                |  You love her.        = TEXT            |           |     X     |           |           |     X     |
                Remark : Of course, for correct testing of these regexes, just copy the text provided, in that way :
                TEST : I love you.
                I love you.          = TEST
                Now, to match all complete non-empty lines which do NOT contain the expression <p class="TEXT">, possibly preceded by some blank characters, with that exact case, use the regex :
                Regex F : (?-is)^(?!\h*<p class="TEXT">).+\R
                |               Lines Scanned               |  Regex F  |
                |  <p class="TEST">I love you.<br>          |     X     |
                |      <p class="TEXT">She loves me.<br>    |           |
                |  <p class="ABCD">It is not about me.<br>  |     X     |
                |  <p class="TEXT">You love her.<br>        |           |
                  yes, @guy038 . but if I have opposite scenario:
                  1. <p class="TEXTA">She loves me.</p>
                  2. <p class="TEXTA">She loves me.<LLbr>
                  3. <p class="TEXTA">It is not about me.<AAbr>
                  4. <p class="TEXTA">She loves me.
                     </p>
                  And I want to select all tags which contains <p class="TEXTA"> but does not contains </p>. So I want to select only the 2 and 3 lines. How can I do this ?
                    this regex will work on your new example:
                    find what: ^(.*?)TEXTA(.*?)(.|\R)(.*?)</p>\R
                    so from a copy of your example:
                    (it has to have an empty line after all texts for a correct newline \R detection on multi line <p>…</p> tags like the 4. you’ve given in your example)
                       </p>
                    it will delete everything and leave you with:
                    if this does not work with your real data, please provide us with a real data example and how your result should look like
                      Hi, @neculai-i-fantanaru, and All
                      In that case, you could use the regex (?-i)<p class="TEXTA">[^<>]+<(?!/p).+?>
                      Notes :
                      • First, this regex looks for the literal expression <p class="TEXTA">, with that exact case
                      • Followed with a non-empty range of characters, either different from < and >, till an < symbol
                      • Followed with a non-empty range of standard characters till the nearest > symbol, but ONLY IF the string /p cannot be found, right after the < symbol !
                      Just test it, with that text below :
                      <p class="TEXTA">an other
                      test </abc>
                      <p class="TEXTA">She loves me.</p>      <p class="TEXTA">She loves me.</123>
                         <p class="TEXTA">She loves me.<LLbr>    <p class="TEXTA">She loves me.</p>
                         </p>
                      <p class="TEXTA">It is not about me.<AAbr>     <p class="TEXTA">It is
                       not about
                       me.<p>
                         </p>
                      As I suppose that you would like to replace any bad ending tag, like </abc>, /123, <LLbr>, <AAbr>, or even <p> with the right ending tag </p>, use the following regex S/R :
                      SEARCH <p class="TEXTA">[^<>]+<\K(?!/p).+?(?=>)
                      REPLACE /p
                      Notes :
                      • If you just perform the search part, it just matches any bad ending tag, without the < and > boundaries, which is different from /p
                      • Remember that the \K syntax forces the regex engine to forget everything already matched and reset the working position to the location, right after the < symbol !
                      • If you click on the Replace All button ( not the Replace one ), any bad ending tag is then changed into </p>
                        @guy038 said:
                        (?-i)<p class=“TEXTA”>[^<>]+<(?!/p).+?>
                        Your regex is great. But I just find another case that you may update regex, if you want. Strange thing. I did not take this into account. That can be some other tags in the same tag. For example:
                        <p class="TEXTA">I believe in love<em>but only if</em>you can make me smile</p>
                        So, to update my last scenario:
                           </p>
                        5.<p class="TEXTA">I believe in love<em>but only if</em>you can make me smile</p>
                        6.<p class="TEXTA">I believe in love<em>but only if</em>you can make me smile</title>
                        So, the regex it should select lines 2,3 and 6 . Right now, your regex select also the line 5 (because of that 2 <em></em> witch is not good).
                          Ah, OK ! So, I’ve created a regex, using a recursive pattern ( due to the (?1) subroutine to group 1, located inside the group whose it refers to ), which allows the search of any block :
                          • Beginning with the tag <p class="TEXTA">
                          • Ending with a tag, different from </p>, which ends the line
                          • Containing any correct matched areas <tag>.....<tag, possibly juxtaposed and/or nested, as for instance :
                          <p class="TEXTA">.......<abc>.....<def>...
                          ....</def>...........</abc>.........<123>........</123>......<456>....
                          ...</456>............
                          ........<Niv1>.......<Niv2>.........<Niv3>......
                          ...<Niv4>.......<XXX>...........</XXX>............</Niv4>......
                          ..............</Niv3>..........
                          .......</Niv2>..........
                          .........</Niv1>...........<bla bla bla>
                          Highly unlikely case, isn’t it !
                          So, here is the regex :
                          (?-i)<p class="TEXTA">(?:([^<>]+<(\w{1,10})>([^<>]+|(?1))</\2>[^<>]+)+|[^<>]*)<(?!/p)[^<>]+?>(?=\R)
                          And, again, if you just want to catch the wrong ending tag use the regex :
                          (?-i)<p class="TEXTA">(?:([^<>]+<(\w{1,10})>([^<>]+|(?1))</\2>[^<>]+)+|[^<>]*)<\K(?!/p)[^<>]+?(?=>\R)
                          Test these regexes, against text below. Note that they match only the blocks with even numbers ( 2, 4, 6, … )
                                   about me
                              </p>
                          4. <p class="TEXTA">It is not
                                   about me.
                              <AAbr>
                          5. <p class="TEXTA">I believe in love<em>but only if</em>you can make me smile</p>
                          6. <p class="TEXTA">I believe in love<em>but only if</em>you can make me smile</title>
                          7. <p class="TEXTA">I believe in love<em>but
                                 only
                          8. <p class="TEXTA">I believe in love<em>but
                                 only
                               if</em>you can make me smile</html>
                          9.  <p class="TEXTA">I believe in love<12345>but
                              only
                              if</12345>you can make me smile</p>
                          10. <p class="TEXTA">I believe in love<12345>but
                              only
                              if</12345>you can make me smile</div>
                          11. <p class="TEXTA">I believe<em> in love<em>but
                            only
                          if</em>you can ma</em>ke me smile</p>
                          12. <p class="TEXTA">I believe<em> in love<em>but
                            only
                          if</em>you can ma</em>ke me smile<h3>
                          13.  <p class="TEXTA">I be<em>lieve<def> in love<em>but
                               only
                               if</em>you can ma</def>ke me smi</em>le</p>
                          14.  <p class="TEXTA">I be<em>lieve<def> in love<em>but
                               only
                               if</em>you can ma</def>ke me smi</em>le</body>
                          15.
                          <p class="TEXTA">I be<abc>lieve<def> in love<em>but
                          only
                          if</em>you can ma</def>ke me smi</abc>le</p>
                          16.
                          only
                          if</em>you can ma</def>ke me smi</abc>le<abcde>
                          17. <p class="TEXTA">I <ab>believe </ab>in love<em>but only if</em>you <123>can make </123>me smile</p>
                          18. <p class="TEXTA">I <ab>believe </ab>in love<em>but only if</em>you <123>can make </123>me smile</a>
                          19. <p class="TEXTA">I <code>believe </code>in love<em>but
                                only if<123>you </123>can
                                make </em>me
                             smile</p>
                          20. <p class="TEXTA">I <code>believe </code>in love<em>but
                                make </em>me
                             smile</tr>
                          21.<p class="TEXTA"></p>
                          22.<p class="TEXTA"><script>
                          23.   <p class="TEXTA">.......<abc>.....<def>...
                          .........</Niv1>...........</p>
                          24..   <p class="TEXTA">.......<abc>.....<def>...
                          ...<Niv3>.......<XXX>...........</XXX>............</Niv3>......
                            @guy038 said:
                            (?-i)<p class=“TEXTA”>(?:([^<>]+<(\w{1,10})>([^<>]+|(?1))</\2>[^<>]+)+|[^<>]*)<(?!/p)[^<>]+?>(?=\R)
                            good morning. I try your regex, both, I don’t know why, but doesn’t select line number 6. Only the lines 2 and 3.
                              again, you will have to add an empty line below 6. if it is the last line of your test document.
                              then @guy038 's regex will find line 6. correctly with your given example.
                              so your document must end with an empty line in order for the regex to work.
                                yes, ok, but if I have an .html file, I will never finnish with this line. :) So, for sure I have a lot of lines and other tags after line six :)
                                anyway, I get it. I remove the last part (?=\R) and works.
                                thank you @guy038
                                And Happy New Year everyone !!
