    2 missing strings not translated from English into French - français
    Scheduled Pinned Locked Moved Translation
    messagesfrenchfind menufrançais
    8 Posts 4 Posters 6.7k Views
    • pboulerieP
      pboulerie
      I am using Notepad++ 7.6 (I can not update to the latest version, because I have no admin rights on my machine at the Uni campus here – for obvious securiry requirements, but I do not have time to test on my personal computer the most recent sub 7.6.x …)
      In the Find window, the following two messages are not translated into French…
      Find: Found the 1st occurrence from the top. The end of the document has been reached.
      (and also : « from the bottom »)
      Find: Can’t find the text “xxxx”.
      PS By the way, sorry I could not submit this new topic here earlier with my GitHub account login sign-in during last november :
      Error
      You do not have enough privileges for this action.
      GitHub account
      Permissions
      Access user email addresses (read-only)
      • Meta ChuhM
        Meta Chuh moderator @pboulerie
        @pboulerie
        this has been translated many versions ago, and is (or should be) translated in your 7.6 as seen at the screenshots below.
        some possible solutions:
        1. try to change to english or any other language and back to french
          (this reloads localization\french.xml from your notepad++ install or portable directory if french.xml was updated to 7.6 but is not yet active)
        2. download the portable 7.6.2 zip version from here, extract it anywhere and try to replace your current localization\french.xml with the new one you can find in this zip folder
          (you will probably not have the rights to do so and need help of an administrateur)
        3. download the portable 7.6.2 version from the link above, extract it to your desktop and use this portable version instead of the installed one
          (sometimes you have sufficient permissions to run executables from folders on your desktop)
        Imgur
        Imgur
        • pboulerieP
          pboulerie
          Merci, j’ai changé dans Paramètres, Préférences, Général, Langue, en basculant entre Français et English
          Thanks. I have toggled between French and English and then back to French via : Settings, Preferences, General, Localization
          By the way, it is strange to see that « Localization » has been translated into « Langue », instead of something like « Langue de l’interface »…
          Then I have restarted Notepad++ and I see several menus still in English.
          I have listed them below.
          Contextual mouse menu in the Windows OS desktop :
          • Edit with Notepad++
          Fichier
          • Restore Recent Closed File
          Macro
          • Trim Tailing and save
          Exécution
          Most of the menus are not translated here / la majorité des menus ne sont pas traduits, par exemple :
          • Launch in Firefox
          • Launch in IE
          Other info are not translated, in the info section at the bottom of the Notepad++ window :
          • length
          • lines
          Alan KilbornA batagyB 2 Replies Last reply Reply Quote 0
          • Alan KilbornA
            Alan Kilborn @pboulerie
            The possible “problem” here could be with the amount of available space?
            • pboulerieP
              pboulerie
              There is plenty of space in the dialog windows to use a longer term there (Windows OS systems are usually PCs with large screens).
              • Alan KilbornA
                @pboulerie
                It could be something that is used in several places and one place needs it to be kept short? I don’t really know, I’m just thinking of possible reasons…that usually people don’t think of when they complain about translations not being ideal. And, BTW, if you are complaining and you want someone with the power to change it to see it, you are doing it in the wrong place. See https://notepad-plus-plus.org/community/topic/15741/faq-desk-feature-request-or-bug-report.
                Really? THANKS! I never knew that. I learned something today!!
                • pboulerieP
                  pboulerie
                  Thank you for the link to the advice about : “FAQ Desk: Feature Request or Bug Report”
                  it’s not guaranteed that a feature request in the Forums will be noticed or followed up on.
                  if I have time, I will open some, as I used to a few years ago:
                  https://github.com/notepad-plus-plus/notepad-plus-plus/issues/created_by/pboulerie
                  PS When I talked of office PCs with very large screens, I meant : in opposition to workpads, tablets, and smartphones with small screens…
                  • batagyB
                    batagy @pboulerie
                    Hi!
                    Let me answer your questions.
                    This string is translatable, and actual translation is depending on French translator. Otherwise good observation. In Hungarian translation I also use “Language of program interface” in Hungarian.
                    Not everything is translatable.
                    This is not part of the language file, it belongs to windows installer that doesn’t handle right click registry entry localization.
                    Fichier
                    This is a bug for long time (many years). Even if translated, but program displays English string.
                    Macro
                    This is a name of the Macro itself, and not part of the interface. Not to be translated.
                    Exécution
                    • Launch in Firefox
                    • Launch in IE
                    These are not translatable as of now, they are not in language file.
                    • length
                    • lines
                    These string in the status bar are not in the language file either at the moment, they are not translatable.
