    How to configure so that the current Style affects current text input only
    3 Posts 2 Posters 1.2k Views 1 Watching
    • J Offline
      jokinjo
      I have a text file that I want to annotate with a text style that stands out from the original content.
      I tried global Style: Global Override AND Global Style : Default Style (in the Style Configurator). Each of these reformats the original content as well as the current input text (for the annotations.)
      As far as I can see, nobody has wanted to do this? Thanks! I am hoping that this is an easy one and not a duplicate question.
      • Eko palypseE Offline
        Eko palypse @jokinjo
        @jokinjo
        that is basically what lexers do, which means you need to define your own
        user defined language or if it is all about having some text highlighted in a different
        color then you might think about using (mouse-right-click in document) Style token
        feature.
        J 1 Reply Last reply Reply Quote 3
        • J Offline
          jokinjo @Eko palypse
          @Eko-palypse
          I finally got it using a user-defined language.
          Thank You So Much!
