    best way to get debug output while developing plugins?
    globalextended charsdifference
    5 Posts 4 Posters 2.3k Views 2 Watching
    • Dimple sharmaD Offline
      Dimple sharma
      What is the best way to get debug output while developing plugins?
      I am new to Notepad++ plugin development, and can’t seem to find any good way to debug my plugin.
      Alan KilbornA Eko palypseE 2 Replies Last reply Reply Quote 0
        Alan Kilborn @Dimple sharma
        @Dimple-sharma
        Well, running under a IDE capable of single-step debugging would be best. Depending upon what exactly your need is, perhaps OutputDebugString would work? https://msdn.microsoft.com/en-us/library/windows/desktop/aa363362(v=vs.85).aspx
        • Eko palypseE Offline
          Eko palypse @Dimple sharma
          @Dimple-sharma
          The most comfortable way would be to build a project with npp, scilexer and your plugin in VS2017.
          Configure your output paths accordingly - done.
          Note, only debug builds allow to use unsigned SciLexer dll.
          If you want to test a release build you need to copy over an official SciLexer dll or modify
          the necessary code in npp.
          dailD 1 Reply Last reply Reply Quote 3
          • dailD Offline
            dail @Eko palypse
            @Eko-palypse
            I always debug mine by setting VS to copy the built DLL file to Notepad++'s plugin directory, then set the notepad++.exe as the application to start debugging (no need to build N++ or SciLexer). You cant step through Notepad++ but you can step through the plugin code (which has always been sufficient for what I need).
            Eko palypseE 1 Reply Last reply Reply Quote 4
              Eko palypse @dail
              @dail
              Thank you, very much appreciated - yes, that might be the easiest way to debug plugins.
