    Gmod Lua Lexer is not compatible with newer versions of Notepad ++
    3 Posts 3 Posters 4.2k Views 1 Watching
    • Jumble DropsytJ Offline
      Jumble Dropsyt
      Im trying to learn how to make SWEPS in Gmod, so I can make wacky weapons. But Gmod Lua Lexer doesnt like it. It says, Do you want to uninstall Gmod Lua Lexer to prevent this error message from appearing again? Does somebody know how to fix this?
      • M Offline
        micmou
        Sorry for the late reply but I have a fix for you.
        Take this and save it as GmodLua.xml and put it in your plugins/config folder
        https://pastebin.com/f6cG6PVx
        Note the file isnt mine it was grabbed from the Facepunch forums.
        Edit: Hmm that is a weird double post?
        владус . playВ 1 Reply Last reply Reply Quote 0
        • владус . playВ Offline
          владус . play @micmou
          @micmou Maybe for him too late you helped me very much thanks bro
