    Notepad++ hangs after changing style
    14 Posts 4 Posters 4.1k Views 1 Watching
    • blackerkingB Offline
      blackerking
      Hello Everybody,
      after some time using notepad++ it hangs immediately after opening.
      After deleting the style.xml file it will start normaly.
      But changing into an other style will break it immediately.
      Whats wrong? What files are needed to solve this issue?
      Thank you in advance.
      Meta ChuhM andrecool-68A 2 Replies Last reply Reply Quote 0
      • Meta ChuhM Offline
        Meta Chuh moderator @blackerking
        welcome to the notepad++ community, @blackerking
        we would need some more information and testing from you, to be of assistance.
        • please download the portable notepad++ version 7.6.3 from >>> here <<<.
        • extract npp.7.6.3.bin.zip to your desktop.
        • run the portable version by double clicking on the notepad++.exe inside of the npp.7.6.3.bin folder on your desktop.
        • change any styles and check if notepad++ still hangs.
        note: the portable notepad++ can coexist with your installed notepad++ and runs completely isolated, making it ideal for testing purposes.
        anything you try out there, will not modify your installed version.
        if the portable version behaves as you would expect, we can probably exclude any system wide problem, and begin to analyse your installed version:
        • close the portable notepad++ and open up your installed notepad++.
        • go to the menu ? > debug info... click on copy debug info into clipboard and paste this information here, for further analysation.
        good luck and happy testing.
          blackerking
          After changing the style - the portable Version hangs too. :-(
            Alan Kilborn @blackerking
            @blackerking
            Well since this apparently doesn’t happen for EVERYONE, how about a more exact set of steps you are doing?
              blackerking
              No Problem:
              • Starting NP++ without selected Style
              • Goto: Settings -> Style Configurator…
              • Change: Selected theme: “Default” to “Choco” (other styles has the same effect)
              • NPP hangs, uses about 10-20% of CPU Power , shortly after taskmanager declares as hanging.
              • Kill Process
              Suddenly this Problem appeared some time ago and a complete deinstallation worked fine - for some time.
                @blackerking
                i can not reproduce this on windows 10 and windows 7 using notepad++ 7.6.3, both installed and portable, both x86 and x64.
                the next thing i would try, is to create a new local windows user account, log off the current account, log in to the new account, and retry with both the installed version, and the portable version, to exclude that the current user hive has something that produces this.
                if this does not work either, i would boot into safe mode, and try notepad++ styles like choco there, to eliminate the posibility, that any other auto starting software is causing this.
                also your debug information might help.
                  blackerking
                  Notepad++ v7.6.3 (32-bit)
                  Build time : Jan 27 2019 - 17:20:30
                  OS : Windows 10 (64-bit)
                  Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll NppExport.dll
                    @blackerking
                    thank you for your debug info.
                    this looks exactly as clean as my windows 10 test setup, where i just tried to reproduce your experience by changing to choco and other styles.
                    so we can exclude something wrong in notepad++ itself, as your installed version looks clean and the portable version produces the same result.
                    currently i have no further ideas, than trying out a new account as well as trying out safe mode. sorry about that.
                    • andrecool-68A Offline
                      andrecool-68 @blackerking
                      @blackerking
                      Use the utility AppCrashView, it will show exactly what the program freezes.
                      blackerkingB 1 Reply Last reply Reply Quote 1
                        blackerking @andrecool-68
                        @andrecool-68
                        Version=1
                        EventType=AppHangB1
                        EventTime=131962665197113234
                        ReportType=3
                        Consent=1
                        UploadTime=131962665210081937
                        ReportStatus=97
                        ReportIdentifier=d42494ea-4e4c-4931-8d8d-f9a894e57e3e
                        IntegratorReportIdentifier=1d195178-4db5-4296-8e52-bb243d3ed7e5
                        Wow64Host=34404
                        Wow64Guest=332
                        NsAppName=notepad++.exe
                        OriginalFilename=Notepad++.exe
                        AppSessionGuid=00003ea0-0002-0027-3950-c9c757d3d401
                        TargetAppId=W:0006f0f7a16f44fd889d56ff6c39d66b413200000904!0000bd12e669b3c7b0587db5a7e2b98b5a3f8cc5b13a!notepad++.exe
                        TargetAppVer=2019//01//27:16:22:21!2c8379!notepad++.exe
                        BootId=4294967295
                        TargetAsId=2703
                        IsFatal=1
                        Response.type=4
                        Sig[0].Name=Anwendungsname
                        Sig[0].Value=notepad++.exe
                        Sig[1].Name=Anwendungsversion
                        Sig[1].Value=7.6.3.0
                        Sig[2].Name=Anwendungszeitstempel
                        Sig[2].Value=5c4ddabd
                        Sig[3].Name=Absturzsignatur
                        Sig[3].Value=b213
                        Sig[4].Name=Absturztyp
                        Sig[4].Value=134217728
                        DynamicSig[1].Name=Betriebsystemversion
                        DynamicSig[1].Value=10.0.17134.2.0.0.256.48
                        DynamicSig[2].Name=Gebietsschema-ID
                        DynamicSig[2].Value=1031
                        DynamicSig[22].Name=Zusätzliche Absturzsignatur 1
                        DynamicSig[22].Value=b213181e8089ec1a275d74c7bfcf4c4b
                        DynamicSig[23].Name=Zusätzliche Absturzsignatur 2
                        DynamicSig[23].Value=7ae3
                        DynamicSig[24].Name=Zusätzliche Absturzsignatur 3
                        DynamicSig[24].Value=7ae3b49ef483ea6a50c6da2a1e6280d1
                        DynamicSig[25].Name=Zusätzliche Absturzsignatur 4
                        DynamicSig[25].Value=b213
                        DynamicSig[26].Name=Zusätzliche Absturzsignatur 5
                        DynamicSig[26].Value=b213181e8089ec1a275d74c7bfcf4c4b
                        DynamicSig[27].Name=Zusätzliche Absturzsignatur 6
                        DynamicSig[27].Value=7ae3
                        DynamicSig[28].Name=Zusätzliche Absturzsignatur 7
                        DynamicSig[28].Value=7ae3b49ef483ea6a50c6da2a1e6280d1
                        UI[3]=Notepad++ : a free (GNU) source code editor reagiert nicht
                        UI[4]=Wenn Sie das Programm schließen, gehen möglicherweise Informationen verloren.
                        UI[5]=Programm schließen
                        UI[6]=Programm schließen
                        UI[7]=Programm schließen
                        LoadedModule[0]=C:\Users\Franz\Desktop\Neuer Ordner (2)\notepad++.exe
                        LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
                        LoadedModule[2]=C:\WINDOWS\System32\KERNEL32.DLL
                        LoadedModule[3]=C:\WINDOWS\System32\KERNELBASE.dll
                        LoadedModule[4]=C:\WINDOWS\SYSTEM32\apphelp.dll
                        LoadedModule[5]=C:\WINDOWS\System32\SHLWAPI.dll
                        LoadedModule[6]=C:\WINDOWS\System32\msvcrt.dll
                        LoadedModule[7]=C:\WINDOWS\System32\combase.dll
                        LoadedModule[8]=C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17134.590_none_42ead2d644e6098e\COMCTL32.dll
                        LoadedModule[9]=C:\WINDOWS\System32\ucrtbase.dll
                        LoadedModule[10]=C:\WINDOWS\System32\GDI32.dll
                        LoadedModule[11]=C:\WINDOWS\System32\RPCRT4.dll
                        LoadedModule[12]=C:\WINDOWS\System32\gdi32full.dll
                        LoadedModule[13]=C:\WINDOWS\System32\SspiCli.dll
                        LoadedModule[14]=C:\WINDOWS\System32\msvcp_win.dll
                        LoadedModule[15]=C:\WINDOWS\System32\CRYPTBASE.dll
                        LoadedModule[16]=C:\WINDOWS\System32\USER32.dll
                        LoadedModule[17]=C:\WINDOWS\System32\bcryptPrimitives.dll
                        LoadedModule[18]=C:\WINDOWS\System32\sechost.dll
                        LoadedModule[19]=C:\WINDOWS\System32\win32u.dll
                        LoadedModule[20]=C:\WINDOWS\System32\SHELL32.dll
                        LoadedModule[21]=C:\WINDOWS\System32\cfgmgr32.dll
                        LoadedModule[22]=C:\WINDOWS\System32\shcore.dll
                        LoadedModule[23]=C:\WINDOWS\System32\windows.storage.dll
                        LoadedModule[24]=C:\WINDOWS\System32\advapi32.dll
                        LoadedModule[25]=C:\WINDOWS\System32\kernel.appcore.dll
                        LoadedModule[26]=C:\WINDOWS\System32\profapi.dll
                        LoadedModule[27]=C:\WINDOWS\System32\powrprof.dll
                        LoadedModule[28]=C:\WINDOWS\System32\FLTLIB.DLL
                        LoadedModule[29]=C:\WINDOWS\System32\CRYPT32.dll
                        LoadedModule[30]=C:\WINDOWS\System32\MSASN1.dll
                        LoadedModule[31]=C:\WINDOWS\System32\WINTRUST.dll
                        LoadedModule[32]=C:\WINDOWS\System32\COMDLG32.dll
                        LoadedModule[33]=C:\WINDOWS\SYSTEM32\dbghelp.dll
                        LoadedModule[34]=C:\WINDOWS\SYSTEM32\VERSION.dll
                        LoadedModule[35]=C:\WINDOWS\System32\ole32.dll
                        LoadedModule[36]=C:\WINDOWS\SYSTEM32\SensApi.dll
                        LoadedModule[37]=C:\WINDOWS\System32\IMM32.DLL
                        LoadedModule[38]=C:\WINDOWS\System32\imagehlp.dll
                        LoadedModule[39]=C:\WINDOWS\SYSTEM32\CRYPTSP.dll
                        LoadedModule[40]=C:\WINDOWS\system32\rsaenh.dll
                        LoadedModule[41]=C:\WINDOWS\SYSTEM32\bcrypt.dll
                        LoadedModule[42]=C:\Users\Franz\Desktop\Neuer Ordner (2)\SciLexer.dll
                        LoadedModule[43]=C:\WINDOWS\System32\OLEAUT32.dll
                        LoadedModule[44]=C:\WINDOWS\SYSTEM32\Msimg32.DLL
                        LoadedModule[45]=C:\WINDOWS\SYSTEM32\uxtheme.dll
                        LoadedModule[46]=C:\WINDOWS\SYSTEM32\PROPSYS.dll
                        LoadedModule[47]=C:\WINDOWS\System32\clbcatq.dll
                        LoadedModule[48]=C:\WINDOWS\SYSTEM32\edputil.dll
                        LoadedModule[49]=C:\Windows\System32\Windows.StateRepositoryPS.dll
                        LoadedModule[50]=C:\WINDOWS\SYSTEM32\urlmon.dll
                        LoadedModule[51]=C:\WINDOWS\SYSTEM32\iertutil.dll
                        LoadedModule[52]=C:\WINDOWS\SYSTEM32\CLDAPI.dll
                        LoadedModule[53]=C:\Windows\System32\WinTypes.dll
                        LoadedModule[54]=C:\WINDOWS\System32\MSCTF.dll
                        LoadedModule[55]=C:\WINDOWS\SYSTEM32\dwmapi.dll
                        LoadedModule[56]=C:\WINDOWS\system32\dataexchange.dll
                        LoadedModule[57]=C:\WINDOWS\system32\dcomp.dll
                        LoadedModule[58]=C:\WINDOWS\system32\d3d11.dll
                        LoadedModule[59]=C:\WINDOWS\system32\dxgi.dll
                        LoadedModule[60]=C:\WINDOWS\system32\twinapi.appcore.dll
                        LoadedModule[61]=C:\WINDOWS\system32\RMCLIENT.dll
                        LoadedModule[62]=C:\WINDOWS\SYSTEM32\WindowsCodecs.dll
                        LoadedModule[63]=C:\WINDOWS\System32\TextInputFramework.dll
                        LoadedModule[64]=C:\WINDOWS\System32\CoreUIComponents.dll
                        LoadedModule[65]=C:\WINDOWS\System32\CoreMessaging.dll
                        LoadedModule[66]=C:\WINDOWS\SYSTEM32\ntmarta.dll
                        LoadedModule[67]=C:\Users\Franz\Desktop\Neuer Ordner (2)\plugins\DSpellCheck\DSpellCheck.dll
                        LoadedModule[68]=C:\WINDOWS\System32\WS2_32.dll
                        LoadedModule[69]=C:\WINDOWS\SYSTEM32\WININET.dll
                        LoadedModule[70]=C:\Users\Franz\Desktop\Neuer Ordner (2)\plugins\mimeTools\mimeTools.dll
                        LoadedModule[71]=C:\Users\Franz\Desktop\Neuer Ordner (2)\plugins\NppConverter\NppConverter.dll
                        LoadedModule[72]=C:\Users\Franz\Desktop\Neuer Ordner (2)\plugins\NppExport\NppExport.dll
                        LoadedModule[73]=C:\Windows\System32\MsSpellCheckingFacility.dll
                        LoadedModule[74]=C:\Windows\System32\USERENV.dll
                        LoadedModule[75]=C:\Windows\System32\Bcp47Langs.dll
                        LoadedModule[76]=C:\Windows\System32\OneCoreUAPCommonProxyStub.dll
                        OsInfo[0].Key=vermaj
                        OsInfo[0].Value=10
                        OsInfo[1].Key=vermin
                        OsInfo[1].Value=0
                        OsInfo[2].Key=verbld
                        OsInfo[2].Value=17134
                        OsInfo[3].Key=ubr
                        OsInfo[3].Value=590
                        OsInfo[4].Key=versp
                        OsInfo[4].Value=0
                        OsInfo[5].Key=arch
                        OsInfo[5].Value=9
                        OsInfo[6].Key=lcid
                        OsInfo[6].Value=1031
                        OsInfo[7].Key=geoid
                        OsInfo[7].Value=94
                        OsInfo[8].Key=sku
                        OsInfo[8].Value=48
                        OsInfo[9].Key=domain
                        OsInfo[9].Value=0
                        OsInfo[10].Key=prodsuite
                        OsInfo[10].Value=256
                        OsInfo[11].Key=ntprodtype
                        OsInfo[11].Value=1
                        OsInfo[12].Key=platid
                        OsInfo[12].Value=10
                        OsInfo[13].Key=sr
                        OsInfo[13].Value=0
                        OsInfo[14].Key=tmsi
                        OsInfo[14].Value=191365
                        OsInfo[15].Key=osinsty
                        OsInfo[15].Value=3
                        OsInfo[16].Key=iever
                        OsInfo[16].Value=11.590.17134.0-11.0.110
                        OsInfo[17].Key=portos
                        OsInfo[17].Value=0
                        OsInfo[18].Key=ram
                        OsInfo[18].Value=16270
                        OsInfo[19].Key=svolsz
                        OsInfo[19].Value=464
                        OsInfo[20].Key=wimbt
                        OsInfo[20].Value=0
                        OsInfo[21].Key=blddt
                        OsInfo[21].Value=180410
                        OsInfo[22].Key=bldtm
                        OsInfo[22].Value=1804
                        OsInfo[23].Key=bldbrch
                        OsInfo[23].Value=rs4_release
                        OsInfo[24].Key=bldchk
                        OsInfo[24].Value=0
                        OsInfo[25].Key=wpvermaj
                        OsInfo[25].Value=0
                        OsInfo[26].Key=wpvermin
                        OsInfo[26].Value=0
                        OsInfo[27].Key=wpbuildmaj
                        OsInfo[27].Value=0
                        OsInfo[28].Key=wpbuildmin
                        OsInfo[28].Value=0
                        OsInfo[29].Key=osver
                        OsInfo[29].Value=10.0.17134.590.amd64fre.rs4_release.180410-1804
                        OsInfo[30].Key=buildflightid
                        OsInfo[30].Value=20107189-4e77-424a-b650-6c490b3e1d50
                        OsInfo[31].Key=edition
                        OsInfo[31].Value=Professional
                        OsInfo[32].Key=ring
                        OsInfo[33].Key=expid
                        OsInfo[34].Key=containerid
                        OsInfo[35].Key=containertype
                        OsInfo[36].Key=edu
                        OsInfo[36].Value=0
                        FriendlyEventName=Beendet und geschlossen.
                        ConsentKey=AppHangXProcB1
                        AppName=Notepad++ : a free (GNU) source code editor
                        AppPath=C:\Users\Franz\Desktop\Neuer Ordner (2)\notepad++.exe
                        ReportDescription=Aufgrund eines Problems kann dieses Programm nicht mehr mit Windows kommunizieren.
                        NsPartner=windows
                        NsGroup=windows8
                        ApplicationIdentity=657632F0F438D22FAD90AAEC3795A993
                        MetadataHash=-107798320
                        andrecool-68A 1 Reply Last reply Reply Quote 3
                          @blackerking said:
                          If you use Notepad++ v7.6.3 (64-bit), are these errors there too?
                            @andrecool-68 no hangups!
                            Build time : Jan 27 2019 - 17:16:47
                            Path : C:\Users\Franz\Desktop\Neuer Ordner (2)\notepad++.exe
                            Local Conf mode : ON
                            andrecool-68A 1 Reply Last reply Reply Quote 1
                              andrecool-68
                              @blackerking said:
                              Use Notepad++ (64-bit)
                                @blackerking said:
                                on Windows 10, there are conflicts with Notepad++
