    auto-ident problem using XML tools plug-in in HTML pages
    4 Posts 3 Posters 1.6k Views 1 Watching
    • Adriano ElleroA Offline
      Adriano Ellero
      Using XML tools plung-in I have issues with <br> tags in HTML pages.
      For each <br> the plug-in add a column as tab-empy space, same as standard HTML tags (i.e. <p> </p>).
      Any hint?
        Ekopalypse @Adriano Ellero
        @Adriano-Ellero
        sorry, don’t understand your question. What do you want to achieve?
        • Meta ChuhM Offline
          Meta Chuh moderator @Ekopalypse
          @Ekopalypse
          i think the xml tools auto formatting/auto indentation (pretty print) has a problem with a html line break written as <br>, as it does not have a closing / tag.
          @Adriano-Ellero
          sorry about not replying to your other thread about <br> yet.
          if my assumption from above is correct:
          i did not find any workaround using xml tools with an unclosed <br> yet.
          the only way i got auto indentation to work is by using a self closing <br/> instead.
          unfortunately many coders use <br> instead of <br/> since it is also valid.
          so until anyone finds any workaround for the xml tools auto indentation, or has a better alternative plugin, which is available for x64, you would have to replace all <br> with <br/>.
            Adriano Ellero
            thanks I did on that way <br />
            all browsers accept that!
