    Problem with UTF files with polish characters
    3 Posts 2 Posters 2.3k Views 1 Watching
    • Adro RA Offline
      Adro R
      Notepad++ 7.6.2
      Scenario like this:
      Create new file:
      write: DĄBB
      save as UTF, open, everything OK
      Create new file:
      write: DĄBBB
      save as UTF,
      open
      file open as “Windows-1252” and presents “DÄ„BBB” and I can’t change codding into UTF
      switch: “Coding in UTF without BOM” do nothing
      But if I remove last “B” and save “DÄ„BB”
      and open again file:
      file open in UTF and presents : “DĄBB”
      can someone help me ???
      • Meta ChuhM Offline
        Meta Chuh moderator @Adro R
        welcome to the notepad++ community, @Adro-R
        unfortunately autodetect character encoding is broken since notepad++ version 7.6. and above.
        currently it is necessary to:
        • go to settings > preferences > misc and disable auto detect character encoding as seen at the screenshot below.
        settings - auto detect character encoding
        • then go to settings > preferences > new document and set your preferred default encoding to e.g utf-8, as seen at the screenshot below.
        Imgur
        after that repeat your testing, it will work now.
        note: a solving regression rollback fix for that issue has finally been commited and pushed to the pull requests, but it has currently been suspended by @donho for yet unknown reasons.
        • Adro RA Offline
          Adro R
          thanks,
          this solves my problem and the file now loads correctly
