    I lost open tabs and probably, files! HELP!
    24 Posts 11 Posters 58.2k Views 2 Watching
      PeterJones @PeterJones
      Here is a PythonScript implementation of it.
      See these instructions for how to run this script in PythonScript
      The script will pop up a dialog. Respond with:
      1. click YES to load the recovered session immediately
      2. click NO to save the recovered session into an XML file that you can later load with File > Load Session…
      3. click CANCEL to ignore the recovered session
      This is only effective if Settings > Preferences > Backup > Enable session snapshot… was checkmarked before you lost your session file. This is only effective if nothing happened to erase %AppData%\Notepad++\backup or equiavlent.
      Script: RecoverLostSession.py
      # encoding=utf-8
      """in response to https://community.notepad-plus-plus.org/topic/17344/
      specifically, translate the ideas behind https://community.notepad-plus-plus.org/post/79695 to PythonScript
      0. Install Python Script plugin, if not yet installed
      1. Use Plugins > PythonScript > New Script, give this a name (like `RecoverLostSession.py`)
      2. Plugins > PythonScript > Scripts > `RecoverLostSession` to recover it
          2. click NO to save the recovered session into an XML file that you can later load with File > Load Session...
      from Npp import editor,notepad,console
      import os
      import tempfile
      class SessionRecovery(object):
          xml_prefix = "<?xml version=\"1.0\" encoding=\"UTF-8\" ?> \n<NotepadPlus> \n<Session activeView=\"0\"> \n<mainView activeIndex=\"2\">"
          xml_suffix = "</mainView>\n <subView activeIndex=\"0\" />\n</Session>\n</NotepadPlus>\n"
          xml_entry1 = "<File firstVisibleLine=\"0\" xOffset=\"0\" scrollWidth=\"64\" startPos=\"8\" endPos=\"8\" selMode=\"0\" offset=\"0\" wrapCount=\"1\" lang=\"None (Normal Text)\" encoding=\"-1\" userReadOnly=\"no\" filename=\""
          xml_entry2 = "backupFilePath=\""
          xml_endentry = "originalFileLastModifTimestamp=\"0\" originalFileLastModifTimestampHigh=\"0\" mapFirstVisibleDisplayLine=\"-1\" mapFirstVisibleDocLine=\"-1\" mapLastVisibleDocLine=\"-1\" mapNbLine=\"-1\" mapHigherPos=\"-1\" mapWidth=\"-1\" mapHeight=\"-1\" mapKByteInDoc=\"512\" mapWrapIndentMode=\"-1\" mapIsWrap=\"no\" />"
          xml_full = ""
          def go(self):
              self.determine_directories()
              self.build_xml()
              s = notepad.messageBox("YES to load recovered session now\nNO to save as a new session file\nCANCEL to ignore recovered session", "Recovered Session", MESSAGEBOXFLAGS.YESNOCANCEL)
              if s == MESSAGEBOXFLAGS.RESULTYES:
                  self.load_session()
              elif s == MESSAGEBOXFLAGS.RESULTNO:
                  self.saveas_session()
              return
          def determine_directories(self):
              cfg_plg_cfg = notepad.getPluginConfigDir()
              (cfg_plg, x) = os.path.split(cfg_plg_cfg)
              (self.cfg_dir, x) = os.path.split(cfg_plg)
              self.bkup_dir = os.path.join(self.cfg_dir, 'backup')
              self.xml_full = self.xml_prefix
              self.session_xml_path = os.path.join(self.cfg_dir, 'session.xml')
              return
          def build_xml(self):
              for (root, dirs, files) in os.walk(self.bkup_dir):
                  for f in files:
                      filepath = os.path.join(root, f)
                      posFile = filepath.find(f)
                      posAt = filepath.find("@")
                      entry_name = filepath[posFile:posAt]
                      this_entry = self.xml_entry1 + entry_name + '" ' + self.xml_entry2 + filepath + '" ' + self.xml_endentry + "\n"
                      self.xml_full += "\n    " + this_entry
              self.xml_full += self.xml_suffix
              return
          def saveas_session(self):
              notepad.new()
              editor.setText(self.xml_full)
              notepad.save()
              notepad.close()
              return
          def load_session(self):
              _, fn = tempfile.mkstemp('.xml')
              f = open(fn, 'w')
              f.write(self.xml_full)
              f.close()
              notepad.loadSession(f.name)
              try:
                  os.remove(f.name)
              except WindowsError as e:
                  if e.winerror == 32: # cannot delete is fine, just ignore it
                      pass
                  else:
                      raise e
              return
      SessionRecovery().go()
        HERE’s another variation on Python code “solving” the problem.
        • C RaghavaC Offline
          C Raghava
          I am also facing the same issue, I am using Notepad ++ 5. +.+
            Terry R @C Raghava
            @C-Raghava said in I lost open tabs and probably, files! HELP!:
            So if what you typed is correct (5.+.+) you are using a seriously old version. Why haven’t you updated? No-one is going to help you on such an old version. The details listed in this post and several like it all refer to much later versions.
