    Position on opening
    5 Posts 3 Posters 1.3k Views 1 Watching
    • Roger MorrisR Offline
      Roger Morris
      Previously, on opening NP++, my cursor was positioned at the point where I was last editing. Now, suddenly, it’s opening at the end of the file. Is there a setting to control this, and has the default behaviour changed recently?
      EkopalypseE Meta ChuhM 2 Replies Last reply Reply Quote 0
        Ekopalypse @Roger Morris
        @Roger-Morris
        normally those information is stored in a file called session.xml,
        which is also storing the information which file to open.
        Could it be that you are working with multiple instances of npp in parallel?
        If so, this doesn’t work nicely with sessions as the last instance of npp closed will
        write the session.xml and it knows only its file and positions.
          Roger Morris
          nope, just the one instance at any one time.
            @Roger-Morris
            did you try to check the session.xml file - is it valid?
            • Meta ChuhM Offline
              Meta Chuh moderator @Roger Morris
              @Roger-Morris
              maybe the log file monitoring function is enabled:
              make sure view > monitoring (tail -f) is disabled.
              if it is enabled it would reload and scroll to the end of a file.
              if it would be activated, you would see an eye instead of a disk at the tab, as seen at the screenshot below.
              Imgur
