    UDL: Code Folding Help
    2 Posts 2 Posters 1.3k Views 1 Watching
    • Christian MajorC Offline
      Christian Major
      Hello! Fairly new to using Notepad++ and have been toying with UDL. I am attempting to create a UDL for a legacy language “Monk”. The language is similar to LISP. I cannot figure out how to get the code folding to work correctly, but I feel that the code folding used for LISP is very close to what I want. Is there a way to mimic that for my Monk UDL? If not, perhaps someone can determine how I can do it manually? Example syntax of Monk below; it’s heavy on parentheses!
         (do ((x 0 (+ x 1))) ((>= x FacilityCount))
           (if (empty-string? (vector-ref Facilities intFacilityNdx))
            (begin
             (set! intFacilityNdx (+ intFacilityNdx 1))
            (begin
             (set! WriteMessageCount (+ WriteMessageCount 1))
          (comment "List of facilies is built, send a message for each facility in the list" "
      Thanks for any help on this!
        Ekopalypse @Christian Major
        @Christian-Major
        what exactly is the problem?
