    Help to replace a string
    2 Posts 1 Posters 785 Views 1 Watching
    • remizikR Offline
      remizik
      included.
      example :
       00:18:41,540 --> 00:18:44,499
       [SIGHS]
       But we're family.
      would become :
       But we're family.
      Thanks for your help :)
      • remizikR Offline
        remizik
        I think I found a solution there :
        https://notepad-plus-plus.org/community/topic/13296/find-and-replace-everything-between-and-including-parentheses
        with this :
        https://i.imgur.com/u1CEkbx.png
        (you have to select the text 1st for some reason … )
