    v 7.6.6 tiggerred auto-updater, after ages
    2 Posts 2 Posters 774 Views 1 Watching
    • V S RawatV Offline
      V S Rawat
      today, thankfully, v 7.6.6 tiggerred auto-updater, after ages, I allowed it to download and it duly installed.
      all my plugins are working well as earlier after update also.
      Great. I don’t know what you had done that had stopped those auto-update message. Glad that it is back.
      btw, where does it download the setup file on disk, so that I can save it for future installs.
      Thanks.
      • Meta ChuhM Offline
        Meta Chuh moderator @V S Rawat
        @V-S-Rawat
        it usually stays in %Temp%, as e.g. npp.7.6.6.Installer.exe.
        you can also always re-download the most recent installers from here: https://notepad-plus-plus.org/download/
        this link will always forward you to the latest version.
        or select any of the older versions if you need them.
