    Disappearing of highlight for reopened tabs
    5 Posts 2 Posters 1.5k Views 1 Watching
    • VadimoffV Offline
      Vadimoff
      Hello! When I exit the Notepad++ with some opened tabs (with my highlighting https://clip2net.com/s/41sVRn2 ) and reopen it then, I see all my tabs opened, but their text is simply black and whight without any highlighting: https://clip2net.com/s/41sVJRl .
      How can I solve it?
      Thank’s a lot.
      • Meta ChuhM Offline
        Meta Chuh moderator @Vadimoff
        welcome to the notepad++ community, @Vadimoff
        usually the session should remember the used highlighting when you re-open notepad++.
        can you please go to the notepad++ menu ? > debug info... > copy debug info into clipboard and paste your debug info here ?
        many thanks and best regards.
        • VadimoffV Offline
          Vadimoff
          @Meta-Chuh said:
          debug info… > copy debug
          Thank you for your quick response!
          My debug info here:
          Notepad++ v7.6.6 (32-bit)
          Build time : Apr 3 2019 - 23:49:50
          Path : E:\Programs\Notepad++\notepad++.exe
          Local Conf mode : ON
          OS : Windows 10 (64-bit)
          Plugins : mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll
            @Vadimoff
            many thanks for your debug information.
            can you please try the following:
            • close notepad++ if it is open.
            • make a copy of your E:\Programs\Notepad++\ folder on your desktop.
            • open up this Desktop\Notepad++\ folder copy and start notepad++ by double clicking on notepad++.exe within this folder.
            • retry opening e.g. another pythonscript .py file and make sure you see the highlighting automatically when loading from disk.
            • close this notepad++ copy and reopen it again, by double clicking on notepad++.exe within this desktop folder.
            if it works, we have to check permissions on E:\Programs\Notepad++\
            if it still does not work:
            please test the following, to verify, if a clean portable notepad++ 7.6.6 32 bit would work on your system.
            • download the notepad++ 7.6.6. portable version from >>> here <<<.
              (the portable version does not require any installation and runs completely independent and isolated from your installed version. all custom settings, as well as any stuff you might want to try at the portable version, will not modify your installed version)
            • extract npp.7.6.6.bin.zip to your desktop.
            • make sure to close all instances of notepad++ that might be running, before starting the portable version at the next step, to make sure you are using this portable version only.
            • open the extracted npp.7.6.6.bin folder and start this portable version by double-clicking on notepad++.exe inside this folder.
              (note: notepad++.exe will just be seen as notepad++, if you have enabled to hide all known file extensions at your explorer settings)
            • retry opening any e.g. pythonscript .py file and make sure you see the highlighting automatically when loading from disk.
            • close this portable notepad++ and re-start it, by double-clicking on notepad++.exe inside the npp.7.6.6.bin folder again, to see whether the highlighting will still be active.
            i hope at least one of the two tests works.
            VadimoffV 1 Reply Last reply Reply Quote 1
            • VadimoffV Offline
              Vadimoff @Meta Chuh
              @Meta-Chuh
              Portable version of notepad++.exe has solved my problem!
              Thank you very mach!
