    ColdFusion Lexer and NPP after (7.5.9)
    11 Posts 8 Posters 9.0k Views 4 Watching
    • Mike GrahamM Offline
      Mike Graham
      The ColdFusion Plugin by Ben Bluemel work fine up to Version 7.5.9 (32 bit) bit I cannot get it to work on any later versions. The instructions for 7.6 advise to make a folder under plugins but that does not work for me. Unfortunately Ben has defected to using sublime so is no longer supporting the ColdFusion plugin.
      Does anyone know how to get the ColdFusion plugin working again?
      Regards
      Mike
      • rddimR Offline
        rddim
        Hello @Mike-Graham
        In my case it run only in x86 version of N++. I didn’t use ColdFusion plugin and I don’t know for what is it and how to use it.
        Step 1
        • Download some portable Notepad++ package 32-bit x86
        • Download nppColdFusion-0.8.1.zip
        • Download sqlite-dll-win32-x86-3070701.zip
        Step 2
        • Extract every archive
        Step 3
        • Create a folder named nppColdFusion in \npp.7.7.bin\plugins dir
          • Place the extracted nppColdFusion.dll file in that folder (i.e in \npp.7.7.bin\plugins\nppColdFusion)
        • Place the nppColdFusion.db3 and nppColdFusion.xml files from config folder in the \npp.7.7.bin\plugins\Config
        • Place the extracted sqlite3.def and sqlite3.dll files in the Notepad++ directory (not the plugins one) - as it is mentioned at the Wiki page of the ColdFusion plugin - i.e. in \npp.7.7.bin dir (where the notepad++.exe lives)
        Eric ScolesE 1 Reply Last reply Reply Quote 5
        • dinkumoilD Offline
          dinkumoil @Mike Graham
          @Mike-Graham
          With the old PluginManager it was possible to declare a plugin package as a library and to define a dependency to such a library in other plugins. This is also the case with the ColdFusion Lexer plugin, it depends on the SQLite package.
          The ColdFusion Lexer plugin wants a certain version of SQLite which can be downloaded >>> here <<<. It’s a ZIP file that contains the file sqlite.dll. Unpack that file to your Notepad++ installation directory, i.e. where your notepad++.exe resides.
          The ColdFusion Lexer plugin package can be downloaded >>> here <<<. In your Notepad++ plugins directory create a folder named nppColdFusion (i.e. with exactly the same name like the plugins DLL file name excluding the .dll extension) and unpack the file nppColdFusion.dll to that folder. Furthermore the plugin package contains a folder named config containing the files nppColdFusion.db3 and nppColdFusion.xml. Unpack these two files to your Notepad++ plugins config directory. For a local installation this is %AppData%\Notepad++\plugins\config and for a portable installation this is <Notepad++-dir>\plugins\config.
          @rddim
          Oh, to late. Was only able to see your posting after I had posted.
          • Eric ScolesE Offline
            Eric Scoles @rddim
            @rddim can you clarify:
            Are you saying that the portable version is required to make the CFML lexer work?
            (I’m not able to get it working using your instructions; I’m using the 32-bit installer-based version, since I also rely on other plugins that only work in 32 bit.)
              Eric Scoles
              Nevermind, figured out the problem: Does not associate file extensions by default. (Now to figure out how to make that work again.)
              • rddimR Offline
                rddim
                @Eric-Scoles
                No, the portable version is not required. I just use it for the testing, because it is more easy. Also in my life I never used an installer-based version. So you can try the @dinkumoil’s explanation, but please note that the SQLite version in my post is different. I just follow the instructions from CFML repo. I hope you can find a sollution.
                dinkumoilD 1 Reply Last reply Reply Quote 1
                  dinkumoil @rddim
                  I’ve used the link to SQLite which I found in old PluginManager’s XML plugin list.
                  • micstanM Offline
                    micstan
                    Tried steps above several times.
                    Tried .xml and .db3 in config, in plugins and in nppColdfusion. Get a consistent error loading a .cfm file of:
                    “nppColdFusion Error
                    ListAll tags length is 0
                    OK”
                    No indication of plugin working. Notepad++ 7.5.9 (32bit)
                    • Joe DeRoseJ Offline
                      Joe DeRose
                      It sounds like some folks have managed to get nppColdFusion working by changing the folder structure, and others (including myself) find Notepad++ crashing even when we follow those instructions scrupulously.
                      I’ve found an alternative to share for those in the latter group (and, perhaps, everyone): Downloading a UDL (User Defined Language) file from Notepad++ directly. Steps as I followed them are:
                      1. Navigate to the User Defined Language Files page at http://docs.notepad-plus-plus.org/index.php/User_Defined_Language_Files.
                      2. Scroll down to “Coldfusion” [sic], right-click on it, and “Save Link As…” to some location on your hard drive. (“Save Link As…” is the wording in Firefox; it may be slightly different in other browsers.) The default name of the file will be userDefineLang_CF9.xml.
                      3. Open Notepad++ and select “Language > Define Your Language…” from the menu.
                      4. Click the “Import…” button, and select the userDefineLang_CF9.xml file you just saved.
                      5. At that point, exit from the User Defined Language dialog and Notepad++ entirely. (There should be no need to save the file after importing it; saving it should be automatic even though it doesn’t yet appear in the list under “Languages”.)
                      6. Re-open Notepad++. Now, you should see “ColdFusion” under the “Language” menu (at the bottom – not under the letter C).
                      7. Open a *.cfm or *.cfc file, and you will find it code-highlighted.
                      Michael BenoitM 1 Reply Last reply Reply Quote 0
                      • Michael BenoitM Offline
                        Michael Benoit @Joe DeRose
                        @Joe-DeRose Would you be able to post that XML file? The link you specified in step 1 doesn’t appear to be available anymore.
                          @Michael-Benoit , the user @Joe-DeRose hasn’t been here since that single post.
                          In the intervening 8 months, that old collection has been moved to https://github.com/notepad-plus-plus/userDefinedLanguages, and the specific file he mentioned is
                          https://raw.githubusercontent.com/notepad-plus-plus/userDefinedLanguages/master/UDLs/ColdfusionCF9_bySpenster.xml
