    how to add vertical edge(column)?
    4 Posts 3 Posters 2.2k Views 2 Watching
    • Minkyu JungM Offline
      Minkyu Jung
      I wanded to add vertical columns in my notepad++. I found out the way that in setting-editing-show vertical edge in order to add vertical column. Through this, I was just able to add only 1 vertical line. but, I’d like to add several lines in my notepad++ at every 8 digits. Could you please help me for this, if notepad++ can support this?
      dinkumoilD 2 Replies Last reply Reply Quote 0
      • dinkumoilD Offline
        dinkumoil @Minkyu Jung
        @Minkyu-Jung
        These vertical edges are a feature of the underlying Scintilla edit component Notepad++ uses internally. In Notepad++ v7.7 Scintilla has been updated to v4.1.4, thus it is possible to have more than one edge now. Unfortunately there is no user interface in Notepad++ yet to use this new feature.
        But it is possible to activate it with the help of a scripting plugin. Have a look at >>> this topic <<< to learn how to do that with the LuaScript plugin.
        • Michael VincentM Offline
          Michael Vincent
          You can also do it with NppExec on Notepad++ 7.7.
          ::Multiedge
          NPP_CONSOLE keep
          SET LOCAL COLOR = ""
          IF "$(ARGC)"<="1" THEN
              INPUTBOX "Color" : white
              IF "{$(INPUT)}"=="{}" GOTO END
              ENDIF
              SET LOCAL COLOR = $(INPUT)
          ELSE
              SET LOCAL COLOR = $(ARGV[1])
          ENDIF
          IF "$(COLOR)"=="red" THEN
              SET LOCAL COLOR = 255
          ELSE IF "$(COLOR)"=="green" THEN
              SET LOCAL COLOR = 65280
          ELSE IF "$(COLOR)"=="blue" THEN
              SET LOCAL COLOR = 16711680
          ELSE IF "$(COLOR)"=="black" THEN
              SET LOCAL COLOR = 0
          ELSE IF "$(COLOR)"=="white" THEN
              SET LOCAL COLOR = 16777215
          ELSE IF "$(COLOR)"=="yellow" THEN
              SET LOCAL COLOR = 65535
          ELSE IF "$(COLOR)"=="purple" THEN
              SET LOCAL COLOR = 16711935
          ELSE IF "$(COLOR)"=="grey" THEN
              SET LOCAL COLOR = 8421504
          ENDIF
          SET LOCAL COLUMN = 0
          IF "$(ARGC)">="3" THEN
              SET LOCAL COLUMN = $(ARGV[2])
          ELSE
              SCI_SENDMSG SCI_GETCURRENTPOS
              SCI_SENDMSG SCI_GETCOLUMN $(MSG_RESULT)
              SET LOCAL COLUMN = $(MSG_RESULT)
          ENDIF
          // Set to multiedge mode (2363) (3)
          SCI_SENDMSG SCI_SETEDGEMODE EDGE_MULTILINE
          // Add multiedge (2694)
          SCI_SENDMSG SCI_MULTIEDGEADDLINE $(COLUMN) $(COLOR)
          :END
          ::MultiedgeClear
          NPP_CONSOLE keep
          // Clear all multiedge (2695)
          SCI_SENDMSG SCI_MULTIEDGECLEARALL
          // Reset to line mode (2363) (1)
          SCI_SENDMSG SCI_SETEDGEMODE EDGE_LINE
          Then just call with F6 and select the “Multiedge” or “MultiedgeClear” to remove. You can also call from the NppExec console with:
          \Multiedge [color] [column]
          where color is optional and if not provided will prompt. Color can be an integer color value, not just the shortcuts in the script. Column is the column to put it at; otherwise, the vertical edge is drawn at the current cursor’s column position.
            @Minkyu-Jung
            I wrote a plugin that can add an arbitrary number of vertical lines to Notepad++ v7.7 and higher. Its name is ExtSettings. You can download it >>> here <<<. It will also be available soon via PluginsAdmin.
