    PHP syntax not highliting when inside other language string (ver 7.7)
    10 Posts 7 Posters 2.5k Views 2 Watching
    • AsayhemA Offline
      Asayhem
      Php code that is written inside other laguage string is not highlighting in the latest version.
      Javascript example:
      var ScannerName = “<?php echo $_SERVER[‘REMOTE_ADDR’].”[WDT2]“; ?>”;
      The line is interpreted as string (gray color) but php syntax should override the styling and use php coloring in between the <?php ?> tags.
      NP++ ver 7.6.2 works correctly
        You’re seeing it with PHP, not ASP, but you’ll find a few recent complaints about ASP having the same difficuly; it might be the same bug (though I’m not sure / cannot prove it):
        • https://notepad-plus-plus.org/community/topic/17764/defined-asp-style-disappeared-after-7-7-install
        • https://notepad-plus-plus.org/community/topic/17727/update-to-7-7-ver-and-missed-asp-code-style
        • https://notepad-plus-plus.org/community/topic/17696/bug-problem-with-syntax-highlighting-not-working-on-asp-classic-scripts/5
        • AsayhemA Offline
          Asayhem
          Yes I thought the issue is similar.
          Just wanted to report that php syntax has issues as well in case it is gonna get fixed soon.
          • kkmuffmeK Offline
            kkmuffme
            Also having this issue, hope it gets fixed soon bc it’s super annoying.
            • Meta ChuhM Offline
              Meta Chuh moderator @Asayhem
              @Asayhem @kkmuffme
              this purely depends on the scintilla editor component, which is an external project.
              this behaviour is the same in previous notepad++ versions like 7.6.2, unless you had 3rd party highlighting plugins, and/or scripts installed, that could eventually do so.
              you could try to file a feature request at the scintilla tracker, but as php code strings like var ScannerName = "<?php echo $_SERVER['REMOTE_ADDR']."[WDT2]"; ?>"; are interpreted as text as expected, due to being in between two " double quotes, i doubt that it would be accepted.
              note: you can always download the latest SciTE scintilla demo editor, to see any scintilla feature changes.
              many thanks and best regards.
              David WZD 1 Reply Last reply Reply Quote 3
              • David WZD Offline
                David WZ @Meta Chuh
                @Meta-Chuh
                I tried various Scite editor versions (dl from https://www.npackd.org/p/scite) and for the php language and your example, nothing changed since at least v4.0.0
                But I agree something has changed in Notepad++, previously the content in the php tags was highlighted.
                I will download previous versions of notepad++ to compare to v7.7.1…
                  Alan Kilborn @David WZ
                  Why would you obtain SciTe from anywhere but its home site? I don’t know for sure, but often this kind of thing is just asking for trouble…
                  Haha, just noticed that @Meta-Chuh pointed to the same site…and yet you still went out of your way to get some “questionable” version.
                  • David WZD Offline
                    David WZ
                    My bad, I didn’t go far enough in the past !
                    I’ve just seen that notepad++ v7.7 “Upgrade Scintilla from v3.56 to v4.14.”, so I tried v3.5 of Scite and the behaviour has changed…
                    @Meta-Chuh has right and the “problem” comes from Scintilla.
                    By the way, I think I will downgrade to Notepad++ v7.6.6, that will solve my problem for a while…
                    EkopalypseE 1 Reply Last reply Reply Quote 3
                      Ekopalypse @David WZ
                      @David-WZ
                      I assume it is related to the already reported issue.
                      David WZD 1 Reply Last reply Reply Quote 2
                      • David WZD Offline
                        David WZ @Ekopalypse
                        @Ekopalypse Yes it is, I didn’t see it.
