    Notepad++ stays running after exit
    2 Posts 2 Posters 833 Views 1 Watching
    • major4579M Offline
      major4579
      Windows 7 Pro 32-bit
      When I exit Notepadd++, I can still see the program running in Task Manager. Is there anyway to tell Notepad++ to completely shutdown when I exit?
      TIA,
      John
      • Meta ChuhM Offline
        Meta Chuh moderator @major4579
        welcome to the notepad++ community, @major4579
        notepad++ should not stay as an active process when you exit it, except if a plugin prevents a shutdown.
        can you please run notepad++ with the parameter -noPlugin, e.g. by adding -noPlugin to your notepad++ desktop shortcut, or starting notepad++.exe -noPlugin from cmd ?
        also it would come in handy, if you provide us with your debug information by going to the notepad++ menu ? > debug info... > copy debug info into clipboardand pasting it here.
        many thanks and best regards.
