    [Regression] Current line highlight transparency not working
    macrohighlighttransparencycurrent-line
    8 Posts 3 Posters 2.2k Views 1 Watching
    • G Offline
      GoblinAlchem
      The current line highlighting feature is useful, but it becomes misleading if background color is also used in syntax highlighting. A compromise is to use semi-transparent highlighting, or assign an alpha value to the current line background color. To do this, I have found the following instruction in Notepad++ Wiki:
      http://docs.notepad-plus-plus.org/index.php/Current_Line_Highlighting
      I have created a macro which uses the “wParam” parameter to set the alpha value:
      <Macro name="Current line highlight 10%" Ctrl="yes" Alt="no" Shift="yes" Key="72">
      <Action type="0" message="2470" wParam="26" lParam="0" sParam="" />
      </Macro>
      Since Notepad++ 7.6.4, this macro doesn’t work.
      Should I use different macro code? Is there another way to make the current line highlighting semi-transparent?
      andrecool-68A 1 Reply Last reply Reply Quote 0
      • andrecool-68A Offline
        andrecool-68 @GoblinAlchem
        @GoblinAlchem
        Why not just change the highlight color of the current line in “Style Configurator”
        G 1 Reply Last reply Reply Quote 2
        • G Offline
          GoblinAlchem @andrecool-68
          @andrecool-68, in the style configurator I have specified a custom background color for quoted strings. Now, when the cursor is on a line containing quoted strings, the current line background overrides string background, and strings become harder to see. With the semi-transparency feature both background colors got combined and it looked fine.
            @GoblinAlchem
            You can create a topic with your question here:
            https://github.com/notepad-plus-plus/notepad-plus-plus/issues
            G 1 Reply Last reply Reply Quote 0
            • G Offline
              @andrecool-68, already there. And also a feature request.
              • Alan KilbornA Online
                Alan Kilborn @GoblinAlchem
                So I’m confused…if the inquiries and requests have already been made on the official Notepad++ issues list…since around May 6…why did you open this thread on the forum 6 days ago…?
                andrecool-68A 1 Reply Last reply Reply Quote 1
                  andrecool-68 @Alan Kilborn
                  Control shot (just in case)
                    Alan Kilborn @andrecool-68
                    @andrecool-68 said:
                    Control shot
                    At least it appears he is properly attired, with the helmet, for said “control shot”.
