    Monitoring
    5 Posts 3 Posters 5.7k Views 2 Watching
    • Suzanne BrownS Offline
      Suzanne Brown
      What is monitoring used for? btw, it would be beneficial to have an organized wiki for notepad ++. Is there such a thing?
        If you happen to know linux, tail -f in the menu entry and toolbar hover-over text tells you. If not, it’s not very helpful. :-) For files that are updating frequently (like the log file for a background process – server log, or debug output for some other program, or some such), you often want to watch the file as it grows; the monitoring feature will have Notepad++ poll the file frequently, and if it changes, it will reload the updated file into the editor and scroll down to the last screen.
        Yes and no. No, there isn’t a wiki (there used to be, but it was locked down / frozen years ago due to spam, so the documentation was hopelessly out of date; a few months ago, when Notepad++'s webserver changed hosts, it was finally deleted). But there is a collaborative github project where a new, more up-to-date documentation set can be found: this announcement post gives the links both to the temporary home for the rendered version, and the github repository for the markdown source for the docs.
          Alan Kilborn @PeterJones
          The final link leads to the same place as the earlier link; I think this is the one you wanted for your final link: https://github.com/notepad-plus-plus/npp-usermanual
          However great those documents are, there is currently no mention of “monitoring” in them.
            Whoops; apparently I didn’t copy/paste correctly. Yes, that’s the URL I meant.
            I guess I should have made it more clear that the new documentation is more up-to-date, but not complete.
              Suzanne Brown
              I did take a look at tail -f via “man tail” in Linux. seems like it would have very good application in big data.
