    work on several lines?
    6 Posts 3 Posters 981 Views 1 Watching
    • Zen2coolZ Offline
      Zen2cool
      I’m busy putting order in a txt file to prepare it for injection into a DB sql
      I have lines like this ( 40000) hence the efficiency of removing excess flow with notepad++
      the lines between =====+ and TOTAL EUROS are all different. I can have one as ten.
      +====================== Ticket 16392 =======================
      1 6X50G GO MY LITTLE ONE 2.89 2.89 2.89 B
      1 400G NEXP CAT STER STER 3.49 3.49 3.49 B
      TOTAL EUROS: 3.38
      Is it possible to collect just this with a regex?
      TOTAL EUROS: 3.38
      Is it also possible to transform this (all my lines have different values)?
      B 21.00% 3.30 0.69 3.99
      to
      B 21.00%
      3.30
      0.69
      3.99
      I can’t afford to do any line by line
      Thank you.
        Alan Kilborn @Zen2cool
        @Zen2cool
        For the first part, I’m confused about what you want to transform to, so I’ll skip it…
        For the second part, you could try matching with this:
        ^(B\s\d{1,2}\.\d+%)\s(\d+\.\d+)\s(\d+\.\d+)\s(\d+\.\d+)
        And replacing with this:
        \1\r\n\2\r\n\3\r\n\4\r\n
        Search mode must be set to Regular expression, of course…but you seem to know that already.
        Zen2coolZ 1 Reply Last reply Reply Quote 2
        • Zen2coolZ Offline
          Zen2cool
          Thanks,
          for the first part I just want to get what’s between
          +====================== Ticket xxxx ======================= and TOTAL EUROS: xxxx
          II have (xxxx) 40,000 tickets. !
          I’ll try the rest tonight.
          Thanks
          Rudy
          • Zen2coolZ Offline
            Zen2cool
            I just want to keep what’s between
            +====================== Ticket 16392 =======================+
            TOTAL EUROS:
            and between these two lines I can have between 1 and 10 lines of text for example
            • Zen2coolZ Offline
              Zen2cool @Alan Kilborn
              Thank you again, for the second part
              regards,
                Hello, @zen2cool and All,
                If I understand you, correctly, you would like that, given the text :
                TOTAL EUROS: 3.38
                You expect the text :
                Am I right about it ? If so, use this regex S/R :
                SEARCH (?-is)^.+Ticket.+\R\R|\RTOTAL EUROS.+\R
                REPLACE Leave Empty
                Best Reards,
