    Notepad++
    3 Posts 3 Posters 859 Views 1 Watching
    • ravivarma kvR Offline
      ravivarma kv
      Hi.
      I have the data as below:
           2433 George has a pillow.
      **nothing new
      **all the bad news
      What is happening.
      13984 good to know
      Adam knows everything
      **not in a good way
      12 | new to Columbia
      **im in a mood
      I have to merge the line beginning with space with the following lines that do not begin with spaces.
      Expected result: (in 3 lines)
      2433 George has a pillow.nothing newall the bad newsWhat is happening.
      13984 good to knowAdam knows everythingnot in a good way
      im in a mood
      Can anyone please help me how to execute this in Notepad++
        Terry R
        @ravivarma-kv said in Notepad++:
        This is a quick solution, however not entrely elegant as it will need running multiple times until no more changes occur.
        It works on the premise that we look for a line with a space at the start, then if the following line does not have a space at the start it will merge both lines. By repeatedly running it it will grow the line with a space at the front by appending a “non-space” line at the rear.
        Hopefully you know how regexes work. So under the Replace Menu.
        Find What:^(\s.+)\R(^[^ ])
        Replace With:\1\2
        Set search mode as “regular expression” and Wrap around ticked. Click on the “Replace All”, do this multiple time until the Replace function returns “0 occurances were replaced”.
          Hello, @ravivarma-kv, @terry-r and All,
          I found out a simple regex, which needs to be executed one time, only ! I just assume, as Terry did, that pure blank lines are deleted, as well !
          So, given, for instance, this sample text below :
           1st line with 1 LEADING space
          This is
          a text
          which does
          NOT have any
          LEADING space
           2nd line with 1 LEADING space
          A single line WITHOUT leading space
           3rd line with 1 LEADING space
          2nd multi-lines text
          with NO
          Leading space
           4th line with 1 LEADING space
             1st line with 3 LEADING space
           5th line with 1 LEADING space
           6th line with 1 LEADING space
          3rd multi-lines text
          WITHOUT any
          leading space
           A last line with 1 LEADING space
          This is a
          very long
          multi-lines text
          with
          NO leading
          space
          for all
          the
          lines !
          Use the following regex S/R :
          SEARCH \R(?=(\x20|\z)|)
          REPLACE ?1$0
          Of course, select the Regex expression search mode. You should get the expected text :
           1st line with 1 LEADING spaceThis isa textwhich doesNOT have anyLEADING space
           2nd line with 1 LEADING spaceA single line WITHOUT leading space
           3rd line with 1 LEADING space2nd multi-lines textwith NOLeading space
           6th line with 1 LEADING space3rd multi-lines textWITHOUT anyleading space
           A last line with 1 LEADING spaceThis is avery longmulti-lines textwithNO leadingspacefor allthelines !
          I verified that I got the same output, using Terry’s regex solution ;-))
          Notes :
          • This regex searches for any kind of EOL characters, followed by, either :
            • A space character or the very end of file ( => Group 1 exists )
            • Any kind of character ( other standard char or EOL char, due the empty alternative |)
          • Due to the conditional replacement syntax ?1$0, this matched EOL character is rewritten ( $0 = Whole match ) only if  the group 1 exists. In all the other cases, it is just deleted
          Remark :
          If you prefer that the joined lines are separated with a space character, we need to distinguish between the standard characters, other than a space char, beginning the subsequent lines and any other character. So, use, instead, the followed regex S/R :
          SEARCH (?-s)\R(?=(\x20|\z)|(.)|)
          REPLACE (?1$0)(?2\x20)
          This time, due to the (?2\x20) conditional replacement, the matched EOL char is replaced with a single space character
          And you’ll get the text :
           1st line with 1 LEADING space This is a text which does NOT have any LEADING space
           2nd line with 1 LEADING space A single line WITHOUT leading space
           3rd line with 1 LEADING space 2nd multi-lines text with NO Leading space
           6th line with 1 LEADING space 3rd multi-lines text WITHOUT any leading space
           A last line with 1 LEADING space This is a very long multi-lines text with NO leading space for all the lines !
