    column separation
    2 Posts 2 Posters 712 Views
    • toti chaloT Offline
      toti chalo
      My file has more than 200,000 lines, with different column numbers, this is my example, but I always need the second and fifth column
      **miel:combis @ gmail. com:yyyy:ippps:flowers:text:123.34.78:126577
      1:chico @ yop .com:wwww:aveni234:tellme
      text:james @ mail .com:1265768566:carrss:ssisso:sabc:aaa
      4:bates @ me .com:13265772833:iiii:gloria:ip:125.45.67:–rI3:alex
      I want it like this:
      combis @ gmail .com:flowers
      chico @ yop .com:tellme
      james @ mail .com:ssisso
      bates @ me .com:gloria
      the mail are united
        Hello, @toti-chalo and All,
        As your file is a colon delimited file, here is a possible solution :
        • Open the Replace dialoag ( Ctrl + H )
        • SEARCH (?-s)^.+?:(.+?:)(.+?:){2}(.+?)(:.*)?(?=\R|\z)
        • REPLACE \1\3
        • Tick the Wrap around option, if necessary
        • Click once on the Replace All button or several times on the Replace button
        Notes :
        • The first part (?-s) ensures that the regex char . will match a single standard character, only ( not EOL ones )
        • Then the next part ^.+?: searches the shortest range of standard chars, from beginning of line till a colon character ( the 1st column )
        • Now, the part (.+?:) represents again the shortest range of standard chars till the next colon character ( the 2nd column), which is stored as group 1, due to the parentheses
        • Next, comes the part (.+?:){2}, which matches the next two columns 3rd and 4th with their ending colon chars
        • Finally, the part (.+?)(:.*)? represents the shortest range of chars, stored as group 2, optionally followed with a colon char and other columns :.* , till a line-break or the very end of the file, due to the look-ahead condition (?=\R|\z), which is not part of the overall match
        In replacement, we simply rewrite the 1st and 3rd groups, standing for the 2nd and 5th columns of your table
