    Python error "TypeError: string indices must be integers, not str"
    4 Posts 3 Posters 6.8k Views
    • Rohit bhatR Offline
      Rohit bhat
      My friend who has a little bit knowledge about machine learning was getting the following python error:
       File "em_sep.py", line 13, in <module>
          if ema_1["confidence_score"] == "50":
      Line 13 of the the code:
      email_s.append(email_1["email_address"])
      Alan KilbornA markfilanM 2 Replies Last reply Reply Quote 0
        Alan Kilborn @Rohit bhat
        @Rohit-bhat
        This should get you started…click HERE.
        • markfilanM Offline
          markfilan @Rohit bhat
          @rohit-bhat said in Python error "TypeError: string indices must be integers, not str":
          TypeError: means that you are trying to perform an operation on a value whose type is not compatible with that operation. An Iterable is a collection of elements that can be accessed sequentially . In Python, iterable objects are indexed using numbers . When you try to access an iterable object using a string or a float as the index, an error will be returned as TypeError: string indices must be integers. This means that when you’re accessing an iterable object like a string or float value, you must do it using an integer value.
          For example, str[hello"] and str[2.1] as indexes. As these are not integers, a TypeError exception is raised. This means that when you’re accessing an iterable object like a string or float value, you must do it using an integer value . If you are accessing items from a dictionary , make sure that you are accessing the dictionary itself and not a key in the dictionary.
          Python supports slice notation for any sequential data type like lists, strings , tuples, bytes, bytearrays, and ranges. When working with strings and slice notation, it can happen that a TypeError: string indices must be integers is raised, pointing out that the indices must be integers, even if they obviously are.
            Alan Kilborn @markfilan
            @markfilan
            Please don’t answer strictly off-topic posts. It only encourages further off-topic postings.
