    XML Tools and Validating using Assert(ion) Tags
    5 Posts 2 Posters 2.4k Views 1 Watching
    • FlurDeChikenF Offline
      FlurDeChiken
      Does the XML Tools plugin support XSD 1.1? I’m using version 3.0.3.0. I ask because I’m trying to use Assert tags but the file fails validation. When I try to validate, I get the following validation error: Element ‘xs:assert’ is not allowed in this context.
      I’ve searched all over to try and determine what I’m doing wrong but to no avail.
      I’m just trying to do a POC for this before I start tackling my larger project. My POC consists of a simple XML and XSD document.
      XML Document
      <?xml version=“1.0” encoding=“UTF-8”?>
      <Person xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
      xsi:noNamespaceSchemaLocation=“schema.xsd”>
      <StudentId>BT00001</StudentId>
      <LastName>Tomson00001</LastName>
      <FirstName>Bob00001</FirstName>
      <MiddleName></MiddleName>
      <low>0</low>
      <high>1</high>
      </Person>
      XSD Document
      <xs:schema
      xmlns:xs=“http://www.w3.org/2001/XMLSchema”>
      <xs:element name=“Person”>
      xs:complexType
      xs:sequence
      <xs:element name=“StudentId” type=“xs:string” minOccurs=“1” maxOccurs=“1”/>
      <xs:element name=“LastName” type=“xs:string” minOccurs=“1” maxOccurs=“1”/>
      <xs:element name=“FirstName” type=“xs:string” minOccurs=“1” maxOccurs=“1”/>
      <xs:element name=“MiddleName” type=“xs:string” minOccurs=“0” maxOccurs=“1”/>
      <xs:element name=“low” type=“xs:integer” minOccurs=“0” maxOccurs=“1”/>
      <xs:element name=“high” type=“xs:integer” minOccurs=“0” maxOccurs=“1”/>
      </xs:sequence>
      <xs:assert test=“low < high”/>
      </xs:complexType>
      </xs:element>
      </xs:schema>
      Anyone’s assistance would be greatly appreaciated. Thank you!
        Ekopalypse @FlurDeChiken
        @Mark-Vance said in XML Tools and Validating using Assert(ion) Tags:
        XSD 1.1
        Looks like not at the moment, see here.
        FlurDeChikenF 2 Replies Last reply Reply Quote 2
          FlurDeChiken @Ekopalypse
          @Ekopalypse
          Well, that’s a bummer…thx for the response!
            @Ekopalypse
            The link you provided that points to GitHub led me to a valid Python 1.1 validating tool and I was able to validate my 1.1 XSD. Thanks again!
            EkopalypseE 1 Reply Last reply Reply Quote 3
              @FlurDeChiken
              How could I have missed that? Thanks for mentioning it.
              Another arrow in my quiver. :)
