    About commit "Fix duplicate names in stylers.model.xml" and the closed issue 7965...
    6 Posts 3 Posters 1.7k Views
      Hello, @don-ho,
      Thanks for taking the issue, below, in consideration ! However, as it is closed,
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/7965
      I just want to point out that, regarding the txt2tags language, there are still differences between the names given in SciLexer.h and those in your commit, for the styles 13 and 14 ?!
      https://github.com/notepad-plus-plus/notepad-plus-plus/blob/master/scintilla/include/SciLexer.h
      #define SCE_TXT2TAGS_ULIST_ITEM 13  // Line 1559
      #define SCE_TXT2TAGS_OLIST_ITEM 14  // Line 1560
      https://github.com/notepad-plus-plus/notepad-plus-plus/commit/e309ec23ec28ac744fd397446a3921d45cd0c4cd
              <WordsStyle name="ULIST" styleID="13" fgColor="E300EE" bgColor="FFFFFF" fontName="" fontStyle="0" fontSize="" />  <!-- 1252 -->
              <WordsStyle name="OLIST" styleID="14" fgColor="E300EE" bgColor="FFFFFF" fontName="" fontStyle="0" fontSize="" />  <!-- 1253 -->
      I’m not totally sure but it seems, that the part _ITEM, in the two names, should be removed in SciLexer.h, doesn’t it ?
      Alan KilbornA Michael VincentM 2 Replies Last reply Reply Quote 0
        Alan Kilborn @guy038
        @guy038
        Why did you put this here and not into the github issue ?
          Hi @alan-kilborn,
          Just for two reasons :
          • Firstly, as a non-coder person, I’m a bit unfamiliar to the global management of the GitHub site !
          • Secondly, I didn’t think that it was worth to open a new issue for this small change :-)
            @guy038 said in About commit "Fix duplicate names in stylers.model.xml" and the closed issue 7965...:
            Ha. Don’t be shy. Not just for coders! :-)
            I wasn’t suggesting that; I meant to add it to the issue you had already done. Even when issues are closed, the discussion can continue, and that way all the info is in one place. The developers can even decide to reopen a closed issue based upon new infos.
              Hi @alan-kilborn,
              Hum… I’m quite silly ! I should have guessed that discussion still goes on, although an issue is closed. I’ll do so, next time !
              But, thanks to your comment, I’m less unfamiliar to GitHub, by now ;-))
              • Michael VincentM Offline
                Michael Vincent @guy038
                I think it may be the other way around. SciLexer.h I believe is supplied from Scintilla so it’d be easier to change our (N++) file to match the names in the SciLexer.h header.
                Cheers.
