    problem by test my plugin with pluginmanager
    2 Posts 1 Posters 754 Views
    • MarioRosiM Offline
      MarioRosi
      Hallo,
      i will publish my plugin and test the rollout with the pluginmanager.
      Howto: https://npp-user-manual.org/docs/plugins/
      The problem:
      By every attempt of installation thows error “SHA-256” secure hash is wrong.
      And the “found-hash” is differend any time.
      Location for setup-zip is my git-hub.
      What can i do?
      regards Mario
        MarioRosi
        … okay solution is found …
        The setup-zip only include the file for “Notepad++/plugin/MYPLUGINNAME/.*”-files. Not into subdir, but direct in root!
        On Github create an “release” with versionnumber and desription. Put in the setup-zip.
        Now can install the plugin over pluginmanager.
        regards Mario
