    Multi-cursor editing
    53 Posts 8 Posters 26.9k Views 2 Watching
    • astrosofistaA Offline
      astrosofista @Ekopalypse
      @Ekopalypse said in Multi-cursor editing:
      thx, but I can already do what your gif shows without having BetterMultiSelection installed just by using my script.
      @Ekopalypse
      You are right. I disabled the plugin and your script does all the work and OP should pay close attention to it.
      Anyway I still believe that the conjuntion of both the plugin and your script creates a better tool. The plugin works nice with contiguous selections, which it can create by draging, and your script extend its capabilities to make distant selections. I thank you for it.
      By the way, have you plans to make the plugin able to search for partial words? At first glance looks like a nice addition.
      Disclaimer: I am not related in any way with the mentioned plugin, just a happy user.
        Ekopalypse @astrosofista
        @astrosofista said in Multi-cursor editing:
        Can be the case absolutely, @dail does a great job with all of his plugins. :-)
        Just select the part of the word you are interest in and it should respect it already. This is a scintilla feature not really my work.
        dailD astrosofistaA 2 Replies Last reply Reply Quote 3
        • dailD Offline
          dail @Ekopalypse
          @Ekopalypse I use BetterMultiSelection in conjunction with LuaScript to select multiple instances and then edit them simultaneously…works quite nicely.
          EkopalypseE Michael VincentM 2 Replies Last reply Reply Quote 2
            Ekopalypse @dail
            @dail
            I have no doubt that this works great. :-)
              Yes, it works fine… almost all the time. In one of my tests Notepad++ ceased to respond and have to quit it via the taskbar.
              Better stop for today.
                Hello, @czmaniak, @alan-kilobrn, @peterjones, @ekopalypse, @astrosofista,
                In that discussion, I suppose that the Multi-Editing option is enabled, in >Settings > Preferences... > Editing and that the BetterMultiSelection and PythonScript plugins are both installed, in your N++ configuration !
                It may be worth to note that, by default, in Notepad++, the multiple cursors editing feature behave differently from the column mode editing and that it is identical only if you install and enable the Better MultiSelection plugin of @dail !
                For instance, assuming the five lines, below, the BetterMultiSelection not enabled and the Python script not used :
                12 56498><717 5123 131
                21 78483><000 0456 235
                16 89410><575 5156 464
                97 89411><056 6045 454
                01 25822><644 8970 544
                If you create a zero-length column selection, through these five lines, between the > and < chars, you’re able to
                type in some chars, even tabulations and/or spaces and you may delete few chars, with the backspace or the Delete key.
                However, as soon as you want to use, for instance, the right arrow key or the Ctrl + Left shortcut, the Home or End key and even the Enter key, these commands do not act for all the lines of the column selection
                Now, click between the > and < chars of the first line. Then, holding down a Ctrl key, click, at the same location, for line 2 to 5. The screen seems similar to before but, this time, we get, I would say, something like a 5 one-line column selection ( instead a 1 five-line column selection ) !
                Therefore, the use of the arrow keys, shortcuts involving arrow keys, the the Home, End key and Enter key correctly act as expected ;-))
                The good news is that IF you enable the BetterMultiselection @Dail’s plugin, from within N++, you can, use this enhanced behaviour, too, when creating a classical column selection ;-))
                Obviously, the @ekopalypse’s python script does not create a column selection but, indeed, places individual cursors on every line, containing a specific word. This explains why if we use the @ekopalypse’s python script, below, we do not need the BetterMultiSeelection, in conjunction !
                from Npp import editor
                first_line = editor.getFirstVisibleLine()
                editor.setTarget(0, editor.getTextLength())
                editor.multipleSelectAddEach()
                editor.rotateSelection()
                editor.setFirstVisibleLine(first_line)
                Of course, this script solution seems more flexible, because it places all the cursors at the end of a specific selected word, so, not necessarily at the same column, in each line !
                Now, and a bit off-topic, I would like some information from Python guru’s people ;-))
                In order to realize this post, I decided to install, manually, on my portable N++ v7.8.5 release, the last V1.5.3 version of the PythonScript plugin, from :
                https://github.com/bruderstein/PythonScript/releases
                • First, I did not know to choose between the PythonScript_Full_1.5.3.0.zip and the PythonScript_Full_1.5.3.0_PluginAdmin.zip archives ! After downloading the two archives, I just realized that they were strictly identical and, also, verified, with WinMerge, that their contents were the same !? So what ?
                • Then I created, as usual, a PythonScript sub-folder, in the Plugins folder
                • Opening the archive PythonScript_Full_1.5.3.0.zip, I noticed that the two dll Python27.dll and PythonScript were at the same level. So, I supposed that, from now on, the Python27.dll file wasn’t anymore along with the Notepad++.exe file
                • Therefore, I just extracted all the contents of the archive in the PythonScript sub-folder, that I just created
                • However, during N++ start-up, I got the message, in French :
                “This application could not start because python27.dll cannot be found. …”
                • Luckily, putting back the Python27.dll library, along with Notepad++.exe, everything is back to normal ;-)) And the consultation of the v1.5.3 documentation works just fine, too, from its new location !
                Alan KilbornA 2 Replies Last reply Reply Quote 2
                  Alan Kilborn @guy038
                  @guy038 said in Multi-cursor editing:
                  PythonScript_Full_1.5.3.0.zip and the PythonScript_Full_1.5.3.0_PluginAdmin.zip … they were strictly identical
                  I also confirm this.
                  No idea as to the “why” of it.
                  This part I could NOT duplicate.
                  For me it worked just fine with python27.dll in the PythonScript subfolder under Plugins.
                    So I tried the following with no BetterMultiselection plugin, nor any Pythonscript influence. I’m interested in what you think about it.
                    I started with this text:
                    123
                    456789
                    and created “a 5 one-line column selection” like you did on the first five lines. Thus the most-recent (i.e., the “main” selection caret) was on the 5th line.
                    My goal in this testing was to use the down arrow (and only that key) to move my “selection carets” so that they were in the same spot in the lower grouping of five lines as they were in the top set of five lines.
                    I found I could not do it.
                    What I obtained was four carets in column 1 and one caret (the original “main” selection one) in between the >< on the last line of the file.
                    To be fair to N++, I did the same test in the Scintilla demo editor, with the same result.
                    Maybe my expectation in this scenario is unrealistic?
                      Ooopppss - did not happen to me yet.
                      Is it possible that a very, very large amount of data had to be selected?
                      I have done a small performance/stress test using this script to generate the test data.
                      editor.appendText('This is a teest to see if it works\r\n'*100000)
                      It took about 1 minute, on my PC, until all 100_000 instances were selected.
                      For a test with 1000 instances, which in my opinion is still not
                      a real world test - I mean, who has 1000 instances of the same word
                      in their source code? - it actually selected it immediately.
                      @guy038 , @Alan-Kilborn
                      I ASSUME one of it, guess which one, is for the plugin admin,
                      maybe a naming thing?? But of course, if both are the same then the
                      non-plugin-admin version could have been deleted.
                      Python27 should be loadable from within plugin directory.
                      There was a change in npp source which allows plugins now to find
                      their needed dlls within its directory.
                      astrosofistaA 1 Reply Last reply Reply Quote 2
                        Hello, @czmaniak, @alan-kilborn, @peterjones, @ekopalypse, @astrosofista,
                        Regarding the Python problem, I deleted my Python install and re-installed the plugin with, unfortunately, the same result. My python27.dll library has version 2.7.17150.1013 and contains 2,649,600 bytes. But, never minds : it should be related to my old Win-XP laptop !!
                        Now, Alan, assuming the text,below :
                        123
                        456789
                        123
                        456789
                        123
                        456789
                        I did your test, without any plugin, involved :
                        • I placed a caret, between the > and < chars inside the first block, so 5 ones, using the Ctrl key
                        • Then, hitting 9 times on the Down arrow, only, I obtained exactly what you got !
                        • Now, cancel any null selection
                        • Create a normal column selection, between the > and < chars of the first block
                        • Then, hitting 9 times on the Down arrow, only, anunique cursor was present on the 5th line of the second block
                        • Now, enable the BetterMultiSelection plugin
                        • Place a caret, between the > and < chars inside the first block, so 5 ones, using the Ctrl key
                        • If you hit 9 times on the Down arrow, only, this time, the 5 carets are correctly located, between the > and < chars of the second block of five lines :-))
                        • Cancel any null selection
                        • If you hit 9 times on the Down arrow, only, again, the 5 carets are correctly located, between the > and < chars of the second block of five lines :-))
                        So, the @dail’s BetterMultiSelection plugin is definitively a must and should be installed and enabled every time ;-))
                        IMPORTANT : To cancel any complicated number of selections, resulting of the use of the BetterMultiSelection plugin, simply hit the ESC key !
                        EkopalypseE astrosofistaA 2 Replies Last reply Reply Quote 1
                          Ekopalypse @guy038
                          @guy038
                          Ahh, yes - this was one of the reason to drop XP support as this
                          API is not supported by XP.
                            No, it wasn’t. It was late and I’m sorry but can’t exactly remember what was the selection to be made, surely the target were partial words. But don’t worry, maybe the issue had other causes. If I can reproduce it will let you know.
                            Best Regards
                              astrosofista @guy038
                              @guy038, @alan-kilborn, All
                              I tried to replicate your tests as long as I understood them, with just Notepad++ basic multiselection feature, that is, disabling the BMS plugin and without running Ekopalypse PS:
                              Giphy
                              In the first test I created a null selection column by pressing Shift + Alt + Down Arrow 5 times. As soon as I moved the caret down with an arrow key, the multiselection got lost. End of test.
                              Second test. Created a null selection column pressing Cntrl + Click 5 times. Moved it down and arrived to line 14 with 5 cursors but misalignated. To resolve this unwanted result hit End and all the 5 cursors aligned at the end lines —or hit Home to get a similar output—. Then went up and got the same as before.
                              Conclusion: It matters how the multiselection is created. I’m really puzzled.
                              Best Regards
                                @astrosofista
                                scintilla knows and uses different selection modes.
                                By using SHIFT+ALT+ARROWDOWN/UP you are creating a rectangular selection. By using CTRL+mouse_click you are creating the stream mode.
                                astrosofistaA 1 Reply Last reply Reply Quote 4
                                  @Ekopalypse
                                  -Thank you. I was unaware of these different modes of selection, considered them as an unique mode, without any difference.
                                  So the selection mode that is created by means of your Python plugin, for example, like in the gif animation you uploaded to this thread two days ago, seems to be a stream mode. Am I right?
                                  Alan KilbornA EkopalypseE 2 Replies Last reply Reply Quote 2
                                    Alan Kilborn @astrosofista
                                    So the selection mode that is created by means of (PythonScript) plugin…seems to be a stream mode.
                                    It’s not explicit in the Python code presented, but most of the P.S. functions that deal with creating selections assume you want stream mode. There are only a few functions that allow you to create column-block selections:
                                    editor.setRectangularSelectionAnchor()
                                    editor.setRectangularSelectionAnchorVirtualSpace()
                                    editor.setRectangularSelectionCaret()
                                    editor.setRectangularSelectionCaretVirtualSpace()
                                      Am I right?
                                      Yes. :-)
                                        astrosofista @Alan Kilborn
                                        Good to know, thank you :)
                                          @Ekopalypse
                                          Thank you :)
                                            astrosofista @astrosofista
                                            Hi @Ekopalypse, All
                                            I think I found the mentioned issue. When a character as a comma (,) is selected —shown at the top of the posted imagen— the Python script works as expected, but things go weird when you select a period or a dot (.) and run the PS —at the bottom of the imagen—, as the multiselection now encompass all the characters of the document:
                                            Hope this helps.
