    Changing Text Direction RTL/LTR hotkey to Ctrl+right/left shift
    4 Posts 3 Posters 4.6k Views 2 Watching
    • amymorA Offline
      amymor
      Hello
      Can i change default hotkey of “Changing Text Direction” to Ctrl+right/left shift like notepad?
      Thanks
        Ekopalypse @amymor
        @amymor
        Described here at npp-user-manual.org.
        • amymorA Offline
          amymor
          @Ekopalypse
          i cant set ctrl+right shift or left shift. is it impossible?
          ty
            PeterJones @amymor
            @amymor said in Changing Text Direction RTL/LTR hotkey to Ctrl+right/left shift:
            @Ekopalypse
            ty
            All keyboard shortcut assignments have to have one actual key, along with 0 or more modifier keys. Ctrl and Shift are both modifier keys (so is Alt), and keyboard shortcuts cannot tell the difference between left-shift and right-shift, so you have to pick an actual key (from the drop-down choices) to go with it.
            You could choose something like Ctrl+Shift+Left and Ctrl+Shift+Right to use the left and right arrows in combination with the control and shift keys. However, both of those are usually mapped to select-word-left and select-word-right. At least in mine, Ctrl+Alt+Shift+Left and Ctrl+Alt+Shift+Right aren’t used, so you could map them to all three modifiers plus the left and right arrow keys.
