    Which searchFlag will help me?
    5 Posts 3 Posters 1.2k Views 1 Watching
    • Peter GoddardP Offline
      Peter Goddard
      I am making a plugin that tries to search for every “<” in a text file and place a new line before it. The problem is that the “<” may be inside of a word or between 2 words. Which searchFlag will help me to specify that I want to do this to all “<”? Here’s an example of what I am working with.help5.JPG
      Thanks
        Ekopalypse @Peter Goddard
        @Peter-Goddard
        the searchFlags tell scintilla only how your search_string needs to be interpreted but don’t, magically, find the positions.
        I find the description quite understandable where is your problem here?
        Peter GoddardP 1 Reply Last reply Reply Quote 0
          Peter Goddard @Ekopalypse
          @Ekopalypse I just want to make sure I get the right one
            @Peter-Goddard
            Again, there is no wrong or right without knowing what you are trying to achieve and how.
            I know you want to find every occurrence of something, but how do you code it? I mean, if you want to use a regular expression, then you have to use SCFIND_REGEXP, but if you want to search only literally, then you should consider SCFIND_NONE …
            Hard to tell which one is the right one.
            • R Offline
              rinku singh
              find < and replace it with \r\n< by regex
