    Is there a way to add an "enter" as part of a replace command?
    5 Posts 4 Posters 1.8k Views
    • Stephen KnappS Offline
      Stephen Knapp
      I have a wikitable that I’m compiling and I’ve got each row set as something like
      |-|4 |Destroyer Kamikaze Class |37.5 |102.6 |9.1 |23.2 |2.9 |1398 |100
      I’d like to replace each - sequence with a
      But I can’t seem to figure out how to format the replace
        Hello @stephen-knapp and All,
        So, if I understood you, clearly, you have lines like :
        and you expect this resulting text :
        Am I right about it ?
        Best Regards
          Alan Kilborn @Stephen Knapp
          @Stephen-Knapp
          To answer the direct question, which was:
          The answer is yes, use Regular Expression for the Search mode, and use the sequence \r\n in the Replace with box, potentially along with other text.
            Hi, @stephen-knapp, @alan-kilborn and All,
            If I presume that my guess was correct, here is the regex S/R :
            • SEARCH ^\|-
            • REPLACE $0\n in an Unix file    OR    $0\r\n in a Windows file
            • Options Wrap around and Regular expression selected
            • Thomas 2020T Offline
              Thomas 2020
              or: Extended
              |-\r\n
