    How to make the levels collapse and uncollapse with same shortcut?
    3 Posts 3 Posters 3.9k Views 2 Watching
    • phenomenal11P Offline
      phenomenal11
      Currently Alt+1, Alt+2, etc. are the shortcuts for collapsing different levels of text.
      Alt+Shift+1 , Alt+Shift+2 etc. are shortcuts for uncollapsing different levels of text.
      Is there any way to make the Alt+1, Alt+2 etc. shortcuts do both collapse/uncollapse level? i.e. make them a toggle.
      It would feel much more natural and easier to use.
      • W Offline
        WinterSilence
        you can say it about any function, for example comment/uncomment. nice idea and not so hard to coding - collect and check changed ranges
          donho @phenomenal11
          @phenomenal11
          Please check my reply here:
          https://community.notepad-plus-plus.org/topic/13146/feature-request-toggle-expand-collapse/14
