    same freeze but not on start up
    7 Posts 3 Posters 2.3k Views 1 Watching
    • eliran shenhavE Offline
      eliran shenhav
      Re: Notepad++ 7.8.7 freeze/whiteout on start
      when i open a file (double click) in some of the cases i get frezze screen. it’s can be after some time when i try to open a file. i try the “no plugin” mode and the problem didn’t solve (still freeze).
      did someone have a solution?
      debug info:
      Notepad++ v7.8.7 (64-bit)
      Build time : Jun 5 2020 - 02:38:56
      OS Version : 1909
      OS Build : 18363.836
      Current ANSI codepage : 1255
      Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll NppExport.dll
      print screen:
        Ekopalypse @eliran shenhav
        @eliran-shenhav
        Does this happen for all files or only for specific ones?
        Can you provide a file which causes such a behavior?
        Or is this a random issue?
          eliran shenhav
          thank’s for your replay.
          it’s look like a random issue.
          i can’t really know for what files it’s can happen.
            @eliran-shenhav
            could it be that the files in question share that these do have long lines?
            Or do these files contain binary data?
              eliran shenhav
              @Ekopalypse said in same freeze but not on start up:
              @eliran-shenhav
              no binary data, sometimes there is files with long lines (not always).
                @eliran-shenhav
                Hard to say. Next time it happens I would note what file it was,
                how big it is, where located and check the content.
                Maybe you can find a pattern to help identify under which circumstances this happen. It may be that the disk is failing as well. (but then you should see events in the eventvwr that an ide port didn’t answer)
                Maybe give it a try and reset npp’s configuration by renaming the config.xml from the %APPDATA%\notepad++ directory.
                On next npp startup a default config.xml will be created.
                de
                • tseGITT Offline
                  tseGIT
                  same problem. The problem is not the “line wrap” - option. Long lines are the problem.
                  For better reading of my logfile i assigned extension LOG to type SQL in %appdata%\notepad++\stylers.xml.
                  After Deassigning LOG works fine, so that will be my workaround until this problem is fixed by a future notepad version. No colored keywords but freezing the editor ist gone.
