    on clickable links - mouse cursor is flickering
    4 Posts 3 Posters 768 Views
    • jablkaJ Offline
      jablka
      I have “clickable links” enabled,
      and have noticed significant mouse cursor flickering when mouse is over the link
      in Notepad++
      It hasn’t been before, I suspect some new version of Notepad++ started this…
      Anybody experience the same? :-(
      Please fix this…
      • jablkaJ Offline
        jablka
        I just found out that the last stable version (without mouse cursor flickering while sliding over links) was Notepad++ 7.8.6
        Onwards versions are flickering…
          Ekopalypse @jablka
          @jablka
          Does not happen to me.
          Could you post your debug info from the ? menu?
          • mkupperM Offline
            mkupper
            My cursor is not flickering when the mouse is over it but it flickers as I move the mouse left/right over a link. It’s possible your system is making npp think the mouse is moving.
            Try disabling and re-enabling clickable links to see if the flickering problem goes away until you exit/restart npp. The enable flag is in Settings / preferences / MISC. / Clickable Link Settings
