    Regex - What once worked now does not. I think.
    5 Posts 3 Posters 691 Views
      Skullmonger
      I’m doing a simple find and replace. I had it working, now it doesn’t work.
      Have I made a mistake? It’s so simple:
      [(A-Z)\.][(A-Z)]
      Or maybe:
      [(A-Z)(\.)][(A-Z)]
      It should find instances of any uppercase alpha character, followed by a “.”, followed by another uppercase alpha character.
      And it worked in the past!
      I do it today and it is ALSO finding any instance of two uppercase alpha characters in a row.
      What have I forgotten here?
      Thanks guys.
        Skullmonger
        OK my time to edit a post is gone so I have to correct the above in a new post:
        I do it today and it is finding any instance of two uppercase alpha characters in a row, and any instance of a “.” followed by an uppercase alpha character.
        Instead of finding “A.B” and NOT “AB”, it is finding “AB” and “.B” and NEVER “A.B”.
          Skullmonger @Skullmonger
          Wait… now if I look at my search history it gives me:
          ([A-Z].)([A-Z])
          I’m an idiot.
          • Alan KilbornA Online
            Alan Kilborn @Skullmonger
            @Skullmonger said in Regex - What once worked now does not. I think.:
            I’m an idiot.
            And since you didn’t put your regex inside backticks when posting, so that it looks like this (the formatting): see how I'm in red
            We really don’t have a lot of confidence in what you’ve said in order to be able to help you (if you still need help, which is unclear).
            • Thomas 2020T Offline
              Thomas 2020
              Maybe that’s it?
              [A-Z]\.[A-Z]
