    Intel Hex not higlighting
    29 Posts 5 Posters 13.1k Views 1 Watching
      Alan Kilborn @David Griffiths
      @David-Griffiths said in Intel Hex not higlighting:
      sorry I only just noticed it. Better late than never
      Wow, that was a long layoff…
      Where should I save the file and how do invoke the script?
      There are some basic instructions for this type of scripting HERE. See the PeterJones Jan 19, 2021 4:12pm posting.
      • David GriffithsD Offline
        David Griffiths
        @Alan-Kilborn Thank you Alan. I have installed the PythonScript plugin and created the script.
        When I open a file containing 9 lines of Intel Hex and run the script, precisely nothing happens ??
        This is on my desktop which does not show the highlighting of the hex file. I then tried on my laptop, which does the highlighting correctly, and the script works.
        So back to the original question, why does my desktop not show the highlighting? Both running NPP v8.1.5
          PeterJones @David Griffiths
          I doubt it’s actually nothing. Fortunately, PythonScript has a console which is useful for debugging: go to the PythonScript menu and show the console, and see if it shows any errors after you run the script.
          So obviously there is something different between the two setups.
          My magic eight ball says “Reply hazy, try again” and then “Concentrate and ask again”. In other words: you haven’t given us enough to go on. You’ll have to provide more information, including the PythonScript console results, and maybe some example data.
            David Griffiths
            David Griffiths
            David Griffiths Aug 15, 2020, 10:24 PM
            I doubt it’s actually nothing. Well actually it is! The console shows nothing at all after the ‘ready’ when I run the script ??
            Python 2.7.18 (v2.7.18:8d21aa21f2, Apr 20 2020, 13:25:05) [MSC v.1500 64 bit (AMD64)]
            Initialisation took 297ms
            Ready.
            This seems to be reporting an AMD processor which it isn’t! It is an Intel i5-6400 ??
            In other words: you haven’t given us enough to go on. Fair comment, but I am not sure what I can add? Here is a sample of the data but I doubt that is relevant.
            :10000000FF050102FFFFFFFFFFFFFFFFFFFF09FFF5
            :10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
            :10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
            :10003000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
            :10004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
            :10005000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
            :10006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
            :10007000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
            :00000001FF
            Both machines are running Win10 Home. Obviously the screen drivers are different. Both running the latest version of NPP.
            Are there any config files I can send?
            Cheers, DG
            Alan KilbornA PeterJonesP 3 Replies Last reply Reply Quote 0
              I’ve never really considered this before, but I think it (the “AMD”) is probably what PythonScript was built with? Or the Python exe it uses was built with it? Regardless, I don’t think it has anything to do with what machine it is currently running on.
              At least you didn’t complain that it isn’t showing the current date but is rather showing Apr 20 2020 (that’s a total joke, but it adds support to that this info is being pulled from somewhere other than your current machine).
                I think that @PeterJones was hopeful that some sort of error message would be produced. As nothing of that ilk appears to be showing, it would seem the script is functioning as @Ekopalypse intended, just maybe not for you.
                  @David-Griffiths said,
                  Actualy, I am @PeterJones, not @Alan-Kilborn,
                  I have to assume it was doing something if it was running. It just wasn’t printing to the console. Edit: but yes, as Alan suggested, I was expecting an error message. When you didn’t see one, I started experimenting more once I had time.
                  Please remember, you are asking about a script that @Ekopalypse wrote a year ago, which I hadn’t ever used. So I’m sorry that I wasn’t able to describe exactly how it should work off the top of my head without ever looking at it.
                  *Python 2.7.18 (v2.7.18:8d21aa21f2, Apr 20 2020, 13:25:05) [MSC v.1500 64 bit (AMD64)]
                  Actually, that’s just what Python reports when it’s compiled in 64bit mode: it’s a historical artifact of the fact that AMD beat Intel to the punch for 64bit architecture on consumer PCs, from what I remember; compilers were often hardcoded with “AMD” in the result, and that’s just stuck because it’s what software developers got used to seeing (and checking) when verifying that it compiled correctly, presumably much to Intel’s chagrin. You can see this even from your cmd.exe prompt :
                  C:\Users\Peter>echo %PROCESSOR_ARCHITECTURE%
                  AMD64
                  C:\Users\Peter>echo %PROCESSOR_IDENTIFIER%
                  Intel64 Family 6 Model 158 Stepping 13, GenuineIntel
                  … where it shows it knows it’s an intel chip, but the architecture is still listed as AMD64.
                  Sorry, I hadn’t noticed the example “intel hex” document in the initial piece of this conversation. I asked for example data because without seeing that example data that you presented now (or going back and seeing it at the beginning), I had no idea what the data would look like, so I had no way of giving the script valid data.
                  I ran the script, and it didn’t immediately do anything, so I went back and re-read the entire thread (seeing the original data… sorry) to see if it gave clues; then glanced through to the source code for print statements; I found if I changed self.debug_mode = False to self.debug_mode = True, it would enable a print. When I reran the script, I saw it print a single checksum. Given it was more than one line of data, I was surprised it only showed one. I clicked somewhere else, and it printed another. So then I started arrowing through. When I got to the first line (the one that had an error highlighted), it “dropped down” a second line after the first, where it showed a separate checksum lined up with the incorrect checksum:
                  Not the best color choice (IMO), but it shows EB instead of F5 as the correct checksum. When I change F5 to EB, the syntax highlighter changes from red to green, and the “dropped down” line goes away.
                  Does it behave the same way for you? If not, turn on the debug printing by changing the line of code, saving, and re-running the script, and look at the console output as you run it. It should look like:
                  Once you know it’s working, then you can change that back to False. Exit Notepad++ and re-enter. The next time you run the script, it won’t be printing to the console anymore, but it should show you the fixed checksums.
                  (And as an aside, you only have to run the script once per load of Notepad++; for that entire session, anytime you enter an Intel HEX document, it will do the checksum as you navigate through the document.)
                  You said last year,
                  BTW I am still none the wiser as to why my desktop PC only wants to show Intel Hex in monochrome ??
                  I had a similar problem: I was using recent v8.1.5, and no highlighting was done for Intel HEX files, even though it was properly recognized as such in the Language Menu. And when I checked the Style Configurator, it didn’t even list it… which meant my stylers.xml didn’t have Intel HEX defined – that probably means that my original installation was from a version that didn’t have that, and since upgrades don’t overwrite an installed stylers.xml, I never got a copy,even though the current repo shows it’s definitely there. I went and downloaded a portable v7.8.9 (which was the rev listed earlier in the thread), and it properly worked. So I looked at my installed %AppData%\Notepad++\stylers.xml, and it was missing the Intel HEX section. So I remedied that:
                  1. exit my installed notepad++ and restart the app (see usermanual: “editing configuration files” for best practice sequence, which these instructions follow)
                  2. open c:\Program Files\Notepad++\stylers.model.xml and %AppData%\Notepad++\stylers.xml (see forum FAQ: “what is appdata” and usermanual: “config file locations”)
                  3. copy the <LexerType name="ihex" desc="Intel HEX" ext="">...</LexerType> from the .model to the appdata, and save
                    • If your stylers.model.xml doesn’t have it, copy from the online copy of the file instead
                  4. exit Notepad++ and restart the app
                  5. now v8.1.5 properly syntax-highlights
                    Alan Kilborn @PeterJones
                    @PeterJones said in Intel Hex not higlighting:
                    This is called a Scintilla “annotation”.
                    I use it in my “python-check-syntax-on-save” script to produce some information that saves me the time of not finding that problem when I run the script, but rather when I save the file.
                    An example:
                    So I know I did an “oopsie” and need to move my from __future__ ... line upward, like this, where all is good:
                    This little syntax checker was inspired by @dail 's which is for Lua: https://dail8859.github.io/LuaScript/examples/luasyntaxchecker.lua.html
                      David Griffiths
                      @PeterJones @Alan-Kilborn Apologies Peter for responding to the wrong person.
                      Yes I see what you illustrated on my laptop but not on my desktop.
                      I just updated styers.xml on my desktop and all is wonderful.
                      Many thanks,
                      DG
