    RegEx - need to replace delimetered string with some its parts
    4 Posts 3 Posters 599 Views 1 Watching
    • Stanisław MędrzeckiS Offline
      Stanisław Mędrzecki
      I have a string:
      A - B - C - D or A - B - C - D - E (the number of delimeters is changing - delimeters contains sapaces before and after “-”)
      I need to replace them with:
      B - C or sometimes C - D or D - E (if the string is shorter then E should be empty - this is optional feature) depending on my needs.
      I saw there is some quite easy formula for that, but I can’t find it.
        Stanisław Mędrzecki
        I made something like that:
        find: (.+) - (.+) - (.+)
        replace: $2 - $3
        find have to be modified for the number of delimiters.
        Maybe there is some more universal way to do that?
        • Olivier ThomasO Offline
          Olivier Thomas
          same result:
          find: .+(. - .)$
          replace: $1
            Ekopalypse @Stanisław Mędrzecki
            @Stanisław-Mędrzecki said in RegEx - need to replace delimetered string with some its parts:
            How do you know when to replace with B - C or sometimes C - D or D - E ?
