    I updated, now all of my tabs/info is gone????? Please help.
    5 Posts 3 Posters 857 Views 1 Watching
    • Norman HaaseN Offline
      Norman Haase
      I updated, now all of my tabs/info is gone??? This never happened with previous updates. Please help.
        PeterJones @Norman Haase
        @Norman-Haase ,
        Hmm. I haven’t normally seen Notepad++ overwrite the session.xml when it updates. What version were you on before, and what version did it update to? If we can replicate the problem, we could send a bug report.
          Norman Haase
          Thanks for your reply Peter. I have no idea of the previous version # (I assume the immediately preceding one, as I haven’t used it for long). It updated to v7.8.9.
            Ekopalypse @Norman Haase
            @Norman-Haase
            check the backup directory to see if there is something.
            It’s either the one where npp is installed or the one under %APPDATA%.
            Depends on your installation.
            Norman HaaseN 1 Reply Last reply Reply Quote 0
              Norman Haase @Ekopalypse
              @Ekopalypse Thank your for your reply. I’ll try that!
