can i use autocomplete for module name with python?
i type this code.
import glob import os print("hoge")but module name do not autocomplete.
print function work with autocomplete.do i need plugin for it?
vscode is very slow.
i want use notepad++ for python and php programming. -
@bge-low said in can i use autocomplete for module name with python?:
What exactly are you expecting here?
thanks for comment.
i want to work autocomplete when i typing module name.
module name and glob function name is do not complete.import glob glob.glob(path) -
https://sourceforge.net/projects/npp-python/
This python script will generate a custom python.xml file used by Notepad++ for auto-completion features when programming in python (function names, arguments, and descriptions), using your own set of imported modules.
