    File display using multiple fonts simultaneously?
    fontfont stylefont viewdisplaybug maybe
    28 Posts 6 Posters 10.7k Views 4 Watching
      PeterJones @M Andre Z Eckenrode
      @M-Andre-Z-Eckenrode said in File display using multiple fonts simultaneously?:
      … did not actively show the extra invisible characters until …
      As @Alan-Kilborn said, I don’t think it suddenly appearing after toggling that particular setting had anything to do with that particular setting.
      My theory: you needed to force Notepad++ to redraw the current window, and toggling the Notepad+±controlled character visibility is one such way. I know in the past, I had the setRepresentation and similar commands seemingly not work because of that.
      It might help to add something like,
      p = editor.getCurrentPos()
      editor.addText(u'Z\uFEFFZ')
      editor.deleteRange(p, editor.getCurrentPos() - p)
      to the end of the script, which adds the character (and some others) then immediately deletes them, which might trigger the redraw.
      Or maybe use
      notepad.new()
      notepad.close()
      which will create a new tab with a new file, then immediately close it… which should force a redraw on the active window that has the special characters
        I think the script is OK the way it is.
        I tested having the script active and changing the View > Show symbol options to various selections.
        I always saw things shown that corresponded to the menu items as well as the special representations the script is doing.
        Thus, I don’t know what happened for the OP, but for me at least everything is fine the way it is.
          PeterJones @Alan Kilborn
          @Alan-Kilborn ,
          Yes, it usually does work right. I’ve just seen rare occasions when setRepresentation or other such code didn’t immediately update in the display, where forcing a re-draw then makes it look right. I have a feeling that this strange outlier situation is the circumstance the OP has found himself in.
          In my day job of programming finicky electronic systems to do specific things, I have found (more often than I like) that even though I’m doing everything I should have to do, it doesn’t start behaving the way I expect it to until I “kick it” with something that shouldn’t matter (akin to my recommendation of opening and closing a new tab), so this is a debug/kluge technique that is now in my toolbox, even in non-physical programming.
          M Andre Z EckenrodeM 1 Reply Last reply Reply Quote 3
          • M Andre Z EckenrodeM Offline
            M Andre Z Eckenrode @PeterJones
            The script is NOT intended to be run multiple times, say, in order to toggle the feature on/off. If this is desired, we can tweak the script
            I wouldn’t mind seeing such a feature, but it’s fine without it. I’d sooner have it also reveal the following code points when the encoding is ANSI/cp1252, which I actually use more often than Unicode:
            129, 141, 143, 144, 157 = All undefined in NPP’s character panel, and everywhere else I’ve consulted.
            160 = Non-breaking space
            Perhaps it was a coincidence; you just thought that was what you saw happen?
            Maybe, but I’m not worried about it enough to investigate.
            I think Show All Characters is bad UI text, because of what it implies
            I agree, and have thought the same thing.
            One email correspondent of mine often sends messages that have ASCII non-breaking spaces in them, which he claims to have no idea why they’re in there, but it trips me up when editing quoted text in my replies, as I often use Ctrl-Left Arrow and Ctrl-Right Arrow to navigate horizontally, and it ends up skipping over multiple words that are only separated by NBS.
            Or maybe use
            I’ll keep them in mind, thanks. It’s actually not that big of a deal.
            • Todd Hoatson 0T Offline
              Todd Hoatson 0 @PeterJones
              @PeterJones wrote:
              It seems to be a bug only in Windows 7, so it’s probably to do with Windows 7 font-handling for Unicode.
              It’s now 2024, and I just had this problem happen for me while using Windows 11.
              So, it’s definitely not a problem with “Windows 7 font-handling for Unicode”. And I don’t believe it is a Windows problem at all…
              Since it’s dependent on the version of Windows, rather than Notepad++, there’s probably not much we can do.
              I (somehow) had an invisible character in my text which I copied from another Windows app into NPP. It did not cause problems with the font-handling in the other app, nor in regular Windows Notepad, nor even in Google Docs.
              It only causes a problem in NPP. Also, I find it odd that Show Symbol > Show All Characters does not reveal that this character is there. Even more disturbing is the following:
              • When I change the Default Style (Settings > Style Configurator) font size to 20, a different set of characters is rendered in the odd font (always including the invisible character).
              • Using Show Symbol > Show All Characters, I see an orange dot as a representation for each space, but for several spaces surrounding the invisible character, the orange dot is misplaced, overwriting some other character. The number of spaces which have this problem, and the amount of the displacement, are dependent on the font size.
              So I conclude that all of this odd behavior is due to some problem in NPP.
                Alan Kilborn @Todd Hoatson 0
                @Todd-Hoatson-0
                And…you’re going to say all of that…and then not say what this “invisible character” actually is?
                I find that incredible.
                  PeterJones @Todd Hoatson 0
                  @Todd-Hoatson-0 said in File display using multiple fonts simultaneously?:
                  It also happens when the font that you have chosen does not contain the appropriate glyphs, and Windows OS (not Notepad++) substitutes a glyph from a different font. (Update: but, unlike the problem from four years ago, it only affects that glyph, not a whole group of glyphs thereafter. The problem that was described four years ago really was Win7-dependent.)
                  It would have been nice if you’d shown a screenshot , so we could know what the problem you are describing manifests as. (Update 2: and, as Alan suggested, telling us what character was causing the problem. I was originally going to give you the benefit of the doubt, that you didn’t know how to figure out the character… but rereading the original discussion above, four years ago, I described how to use the Plugins > MIME Tools > URL Encode to reveal the codes behind even invisible characters. So you could have done at least that much.)
                  And what version of Notepad++ are you using? Because newer Notepad++ have more options in that menu, and Show All Characters (by enabling all those options) does a better job than it used to. If your Show Symbol menu doesn’t look like this screenshot, you should update Notepad++:
                  The Show Non-Printing Characters option is the one that will show alternatives for Zero Width characters and most invisible characters, like the U+2060 WORD JOINER or U+200B ZERO WIDTH SPACE.
                  … and you don’t need all of Show All Characters; as you can see by my screenshot, I tend to turn them all on except End of Line, so that way I don’t get pestered by the CRLF most of the time (I sometimes turn it on when I’m having newline difficulties, or showing someone here something about their newlines, but then turn it back off). But I love that newer Notepad++ allows me to show the special characters for the zero-width and joiner characters, because those are often characters you get from copy/pasting from other apps.
                  Again, A screenshot would help you explain those better. But if I understand correctly, it sounds like you’ve found some Unicode character which wants to join the previous and next character together (which can be used for the modifying accents, or for giving skin tone options to emojis, and similar).
                  That might be. For some problems, Direct Write needs to be turned on; for others, it needs to be turned off; and for some combos of problems, neither option is sufficient. But I think that Show Non-Printing Characters in a recent Notepad++ will help you better diagnose your problem.
                  (You might also need to turn on Settings > Preferences > Editing 2 > Non-Printing Characters > ☑ Apply Appearance Settings to C0, C1, & Unicode EOL (which makes sure it works for ASCII control characters and for the “Unicode EOL” like LS and PS – the characters described in this screenshot from Wikipedia’s Newline#Unicode:
                  • mkupperM Offline
                    mkupper @M Andre Z Eckenrode
                    It depends on the character. Unicode has quite a few characters, such as in the Combining Diacritical Marks block, that will cause odd shifts much like the " the orange dot is misplaced, overwriting some other character" that you are seeing.
                    Notepad++'s “show all characters” feature enables display of what are known as the non-printing characters. The Combining Diacritical Marks and other Unicode characters that cause display changes are defined as “printing characters” and so are not included in the list of things that become visible with Notepad++'s show all characters.
                    When need a true “show all characters” then I do a hex dump of the file. As you seem to have a good idea of where the strange stuff is in your file you can copy/paste just that fragment into a hex dump utility. I see there are on-line hex dumps. There are also on-line UTF-8 decoders that may highlight the unusual or invisible characters you are dealing with.
