    Need help for regular expression - find, insert and delete
    11 Posts 3 Posters 4.7k Views
    • Venus642V Offline
      Venus642
      Hello. I hope for help (absolute newbie).
      I’m trying to change several lines
      Ok I found this regex: ^\d+(-\d+)?\s
      but it delete only numbers and unfortunately it’s not what I’m looking for.
      1. Txt example - rows with numbers:
        02 Txt Txt Txt
        220 Txt Txt Txt
        03 | Txt Txt Txt | 2
        130 | Txt Txt Txt | 2
        etc.
      1. This is OK:
        02 | Txt Txt Txt
        220 | Txt Txt Txt
        03 | Txt Txt Txt
        130 | Txt Txt Txt
        etc.
      The text must be searched. Will not be a | found in the line after the number, it should be set.
      Is a | at the end then delete the last digits (see example 2).
      Big thanks for your help!!
        Alan Kilborn @Venus642
        @Venus642
        Perhaps this is a correct clarification:
        • If a | character is not found after the leading digits on a line, insert it with a space before it and a space after it
        • If a | character is found anywhere else in a line, remove it and anything that follows it (and any space before it)
        • Venus642V Offline
          Venus642
          Thanks Alan for your Info and help.
          How can I change that with regex?
          220 Txt Txt Txt
          To:
          220 | Txt Txt Txt
          Or delete and insert:
          10 Txt Txt Txt | 300
          To:
          10 | Txt Txt Txt
          Sorry. I have no idea how to make regex do it…
          Alan KilbornA astrosofistaA 2 Replies Last reply Reply Quote 0
            @Venus642
            I would do two separate steps:
            find: ^(\d+ )([^|])
            repl: ${1}| ${2}
            and then:
            find: (?-s)^(\d+ \|.*?) \|.*
            repl: ${1}
            Venus642V 1 Reply Last reply Reply Quote 3
            • Venus642V Offline
              Venus642 @Alan Kilborn
              WooooooooW!
              Alan -Big big thanks for your help!
                @Venus642 said in Need help for regular expression - find, insert and delete:
                Pay back by learning about how it worked, so that next time you don’t have to ask. :-)
                Start with information HERE
                • astrosofistaA Offline
                  astrosofista @Venus642
                  Hi @Venus642, @Alan-Kilborn
                  Another option, in one step:
                  Search: (?-s)(?:^(\d+) *?([A-Za-z]+))|( *?\| *?\d+)$
                  Replace: ?1($1 | $2)
                  Have fun!
                  Venus642V 1 Reply Last reply Reply Quote 1
                  • Venus642V Offline
                    Venus642 @astrosofista
                    One step - Perfect…
                    Alan and astrosofist - Top help!
                      One step - Perfect…
                      Yea, I wouldn’t get too bogged down in it needing to be a one-step operation.
                      If it is something you need to do often, you will make it a macro anyway (so you can give it a meaningful name).
                      And if it is a macro, it can just as well be two replacement steps (because, by the nature of macros, multiple steps look like one step).
                      Venus642V 1 Reply Last reply Reply Quote 0
                      • Venus642V Offline
                        Alan I have tested again and your solutions is better in my case.
                          Alan … your solutions is better
                          Well, I certainly wasn’t trying to “win”. :-)
                          I often try to point out that a solution to such a problem doesn’t have to be all crammed into one operation.
                          It can make the operation harder to understand for a novice with regular expressions.
