    copy data inside same document, data is overwitten not inserted
    2 Posts 2 Posters 457 Views 1 Watching
    • Claus Kjær AndersenC Offline
      Claus Kjær Andersen
      When i copy data inside a txt file, to another place in the same file, data is not inserted.
      Mastercase not match 0000365494 0105707294245081213420316156868531 150 160
      0105707294245081213420316156868531 00157072940000132753
      0105707294245081213420316156868651 00157072940000132753
      if i colum mark som text and paste it in the line above, this data
      0105707294245081213420315146854101 00157072940000132272
      0105707294245081213420315146854131 00157072940000132272
      0105707294245081213420315146854161 00157072940000132272
      0105707294245081213420315146854241 00157072940000132272
      this is the result:
      0105707294245081213420315146854131 00157072940000132272Mastercase not match 0000365494 0105707294245081213420316156868531 150 160
      0105707294245081213420315146854161 001570729400001322720105707294245081213420316156868531 00157072940000132753
      0105707294245081213420315146854241 001570729400001322720105707294245081213420316156868651 00157072940000132753
      why is it not just inserted above the other text?
        Alan Kilborn @Claus Kjær Andersen
        @Claus-Kjær-Andersen
        Ummm, because when you have column data in the clipboard, it pastes as a column?
        The solution is to not select text in column mode before you do the copy. Select it in regular (stream) mode.
