    Issues with npftp and ionos (1and1) sftp
    3 Posts 2 Posters 945 Views
    • asirotaA
      asirota
      Hi there,
      Recently I have started to get access denied with IONOS SFTP. I have one account that works and all my others do not. I have confirmed they work fine with filezilla. Is there something special that’s changed in a recent version of Notepad++
      Here’s my current build
      Notepad++ v7.9 (32-bit)
      Build time : Sep 22 2020 - 03:24:22
      OS Version : 2004
      OS Build : 19041.685
      Current ANSI codepage : 1252
      Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll
      • asirotaA
        asirota
        I updated to 64 bit version and still have the same issue
        [NppFTP] Everything initialized
        Connecting
        [SFTP] Host key accepted
        [SFTP] Password authentication denied.
        [SFTP] Unable to authenticate
        Unable to connect
        Disconnected
        Notepad++ v7.9.1 (64-bit)
        Build time : Nov 2 2020 - 01:07:46
        OS Version : 2004
        Plugins : mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll
          PeterJones @asirota
          @asirota said in Issues with npftp and ionos (1and1) sftp:
          Please note that NppFTP is a separate entity from Notepad++. The “problem” is likely in the plugin, not in Notepad++ itself (because Notepad++ itself knows nothing about SFTP or any other such protocol).
          Sometimes, due to the OpenSSL library used by NppFTP plugin, the encryptions/etc that NppFTP knows about is different from the encryptions/etc that your server is willing to use. I have that problem with at least one server.
          However, based on the error messages, it appears your host doesn’t want password authentication. My guess is that in FileZilla, you have that host set to use an SSH key to log in, rather than a password, but that you aren’t trying SSH key with NppFTP. You might have to enable the private key checkbox and fill in the private key file location for the IONOS profile:
          (I think at one point, I also had NppFTP working with pageant or a pageant-equivalent SSH key agent, but I don’t currently have an example of that working available right now, so I don’t remember how it all worked together – but I think it had the checkbox enable but no keyfile in the text box in those settings.)
          If that doesn’t help you, I’m not sure how much more we’ll be able to help you here.
          If you look on your Plugins > NppFTP > About,
          … you will see the Visit NppFTP site which then links to the NppFTP issue tracker, which is where you would go for help specifically on NppFTP. I would recommend, since you can successfully connect to that site using FileZilla, but not with NppFTP, that you share you NppFTP profile settings and the FileZilla profile settings in that issue you create over there. (If you do create an issue with NppFTP issue tracker, it’s generally considered polite to paste a link to the issue you create in this thread, so that anyone who reads your request here can follow it to its conclusion over there.)
          As a workaround for sites that I couldn’t get to work in NppFTP (in the days before my IT department uninstalled FileZilla for me), I would set up FZ to use Notepad++ for the editor, and then I would use FileZilla’s remote-edit feature to edit remote files through FZ using Notepad++. Using FZ+NPP vs NPP+NppFTP were very similar workflows for me, and it didn’t bother me to switch between the two.
