    Need to compile VHDL file using external ModelSim
    4 Posts 2 Posters 1.5k Views 2 Watching
    • Adeeb KhairA Offline
      Adeeb Khair
      Hi
      Please can you and advice how can configure Notepad++ to compile VHDL file using external ModelSim compiler
      Thanks
        PeterJones @Adeeb Khair
        @Adeeb-Khair ,
        You do it the same way you would compile from the Windows cmd.exe command line – except use the variable-name notation from the online docs to get the current filename.
        For example, if the command line to use your compiler were c:\path\modelsim.exe "filename.source", then you could go Run > Run, and type in c:\path\modelsim.exe "$(FULL_CURRENT_PATH)"; if you click Save…, you can save that command into the Run menu, and even give it a keyboard shortcut if you so desire.
        If your command line environment needs environment variables set up, or needs more than one command (like a compile stage then a link stage), I recommend using a plugin like NppExec, where you can define something similar to a windows batch file, but still have access to those variables mentioned earlier.
        A more detailed answer can be found in a post I wrote last fall.
          PeterJones @PeterJones
          Note, this link in the docs gets you closer to the list of variables; I grabbed the wrong anchor when I pasted the link above.
            It’s been asked enough times; I created a FAQ Desk entry for this topic.
